Thread: radio stopped working
Results 1 to 3 of 3
  1. #1 radio stopped working
    Apr 2009
    gurnee
    I have sony cdx-gt330 in my 2008 gp that stop turning on. I checked the fuse on the radio it's not blown is their fuse in the box that could be blown.
  2. #2 Re: radio stopped working
    Then its connection is lose or its burnt out.
  3. #3 Re: radio stopped working
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by biggoltee View Post
    There should be one in the fuse box. Could be a wiring issue. Genital Motors made s**t real difficult 04+. most everything has 12v all the time, even with the key off. They don't have switches like a normal vehicle that turn power to the radio off and on when turn on the ignition switch off or on. They run off of resistance. Less voltage to a certain component, then the computer deciphers the voltage difference to figure out what you want it to do. It's a nightmare. If the fuses are good, take it too a REPUTABLE audio shop that knows what they are doing. The last time I intsalled a CD player in a 04+ gp, I had to get my power source from the HVAC controls. Yeah, it's F'd up. Something was wrong with the wiring. You normally could go to the fuse panel and tap into the radio fuse which only gets power when you turn the key on or to acc. Now it has power all the time, well this one was messed up so there wasn't any power to it at all. You might have a wiring issue and need to get the 12v from a different source.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  1. Temp Gauge stopped working???
    By GXP05er in forum 5.3L V8 (LS4)
    Last Post: 08-10-2010, 07:37 PM
  2. heated seat stopped working
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 11-08-2009, 08:26 PM
  3. speedoand odometer stopped working
    By 1999gpgt in forum General Tech Discussion
    Last Post: 09-27-2009, 09:45 PM
  4. Boost Gauge Stopped Working
    By chipsdubbo89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 03:58 PM
  5. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
