Thread: Switched Ignition Source
Results 1 to 3 of 3
  1. #1 Switched Ignition Source
    Zeeland, MI
    I have a 2004 Grand Prix GTP and I am in the process of wiring in a auto dimming rear-view mirror and need to find a 12 volt ignition wire that can power the mirror and turn off either when the ignition goes out or when the lighting delay goes out.
    If anyone has experience in wiring car accessories and knows which wire to splice into it would be greatly appreciated. Or if anyone has a schematic they could copy for me of the interior wiring, I can take it from there
    Thanks!
  2. #2 Re: Switched Ignition Source
    Apr 2009
    Wausau, Wisconsin
    Tap into your sunroof part in the fuse box.
  3. #3 Re: Switched Ignition Source
    New Brunswick
    Just tap into the sunroof power wire, you can catch it on the sunroof control module and it is the yellow wire in the small connector.
    If you want reverse undim function for when you back up you can catch the backup lamp wire by removing the back seat and rear deck carpet and its the light green wire in the harness you will see goint inside the trunk, Test with an ohm meter to make sure it is the correct one as there may be some for the sound system, etc
    To go from the mirror to the back of the car just run the wire along the roof harness which is behind the headliner on the passenger side.
  1. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
  2. GMPP Warranty source
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 10-06-2009, 11:37 AM
  3. Antifreeze in Oil - How to determine the source.
    By warrenz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 10:10 AM
  4. Source for stock front sway bar?
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2009, 07:44 AM
  5. Most likely source for coolant leak?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:09 AM
