Thread: Amp Wiring
Results 1 to 7 of 7
  1. #1 Amp Wiring
    Canada
    2 quick questions, i have a 98 gp and i was wondering how some people bypassed the firewall and where they did it, and do i connect the amp power cable to the positive terminal on the battery or on the terminal on the fuse box? thats it thanks
  2. #2 Re: Amp Wiring
    GT Level Member sasquatch094's Avatar
    cleveland
    On the passenger side straight in front of the seat on the firewall theres a rubber boot like thing, i poked a whole through that and ran it straight up and down the fender to the battery. You can do either way, depends on how much you subs will be kicking out..
  3. #3 Re: Amp Wiring
    Donating Users crshoveride's Avatar
    Pearl, MS
    like he said there's that little rubber boot/grommet just poke a hole and you just run your power wire through the the positive terminal on the battery. i'm sure you know this just make sure you put the proper fuse in too within 18 inches of the battery i believe. i can snap a couple pics of the grommet if you need.
    1998 Grand Prix GTP Stock for now mods to come soon. Alpine 9885 head unit, 2 JLW3V2 10s, 2 Jensen 650x2 amps, and Tsunami wiring all the way around.
    Ladies and gentleman take my advice. pull down your pants and slide on the ice
  4. #4 Re: Amp Wiring
    Canada
    Quote Originally Posted by crshoveride View Post
    yeah that picture would be nice and yup i got a fuse there
  5. #5 Re: Amp Wiring
    Pearl, MS
    ok dude no problem. i'll see if i can get one in the morning.
  6. #6 Re: Amp Wiring
    Dec 2008
    chicago,illinois
    hope this helps
    going low on 20"
  7. #7 Re: Amp Wiring
    i hooked my amps up exactly how windycitygtp did..if u hook it up this way (the power cable hooked up to the fuse relay box), the amp will shut off wen ur car does..so it wont drain ur batery
  1. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  2. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
  3. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
  4. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
