Thread: How Hard To Hit
Results 21 to 40 of 56
  1. #21 Re: How Hard To Hit
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by I800C0LLECT View Post
    DB Electrical Starter-Alternator > firebird alternator, pontiac alternator, grand am alternator
    Grand Prix High Output Alternators | PowerBastards.com
    Here ya go...they're essentially stock alternators that are rewound (in most cases). You'll have to do a "big 3" upgrade since there's more output. It's upgrading the wires from the alternator to the battery, engine, and ground. Once that is accomplished your light issue will be fixed.
    thnx for the link, i'll save it for future refernce, the Big 3 job sounds like its out of my hands, may have to get a pro sound shop to do it...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #22 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    2 issues...one the powerbastrds link doesnt work, and the 220amp alt, is not listed for 06 model...but most engine componets are the same, think it will still fit?
  3. #23 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    and it is kinda a wiring nightmare, lol here is two pics...
  4. #24 Re: How Hard To Hit
    Feb 2009
    Virginia
    I don't know how you feel about pre-fabbed?
    Dual Solo-Baric L5 & L7 Subwoofer Boxes & Enclosures | Sub Woofer Box | Klaus Audio
    I don't even know if those things match up with your speaker requirements. Some companies just slap things together and call it "good". Email kicker for specific box size requirements. Sealed will be much smaller and my preference since it's closer to accurate.
    I never did really look into the wire diagrams for monsoon sound systems but I have a feeling that since you are going to use a CDA-9887 then you have the capability to tune into whatever the speakers like. If you have passive cross overs for them then dont' worry about active tuning at all. Leave all RCA outs at full range except for subwoofer. Cut that kid off around 70 or 80hz.
  5. #25 Re: How Hard To Hit
    Feb 2009
    Virginia
    Oh...if it turns out your speaker enclosure is too small then you can throw in some poly-fill to help create more resonating space for the speaker. If your box is too big just throw in a 2x4 or so to fill the air space.
  6. #26 Re: How Hard To Hit
    Feb 2009
    Virginia
    I just realized too. The picture of your box...only one speaker is running. Is that because of the head lights dimming?
  7. #27 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    nah I have the 2 subs wired together in series, inside the box. cause they're 4 ohm speakers, so I wired them down to 2 ohms. I bought myself alpine 6.5's and 6x9s and alpine 9887, now I just gotta wait til i get home to install them ...
  8. #28 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    if u look at the first pic, if u notice inside the ported hole, u can see the wires where their wired together
  9. #29 Re: How Hard To Hit
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    you want a hard hit, Screw Kicker, get 1 JL W7, and invest in sign language classes.
  10. #30 Re: How Hard To Hit
    Jul 2008
    sumter,south carolina
    Personally, I'd go listen to the DD's first I'm just not a fan of Kicker. I do like some of the original solobarics and older amps but going mainstream hurt them a lot.
    But my goals are different. I'm all about SQ.
    YESSSSSSSSSS @ DD i have 2 1510's on 500 watt memphis amp and they hit unbelievably hard..some songs i cant listen to at full volume it hurts my chest a lil and i cant see cuz my eyes vibrate so much.
    02 GTP with mods 05 GP for DD
  11. #31 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    what rms are those DD's running at a piece??
  12. #32 Re: How Hard To Hit
    Jul 2008
    Quote Originally Posted by offroadfury6 View Post
    heres the website and here is the specs on the subs i have..i have the lower end model but they still expensive as hell for bein 10's.i can only imagine what the other models can do.
    http://www.ddaudio.com/dd/default.asp
    SPECIFICATIONS
    Series 1500
    Voice Coil Diameter 2.0"
    Magnet Weight 120 oz
    Power Handling RMS/Peak 500/1800
    Suspension 55 mm
    Nominal Impedance S4.0 Ohm / D4.0 Ohm
    DC Resistance 3.4 Ohm
    Model 1508 1510 1512 1515
    Rec Box (cubic ft) 1 1.5 2.5 4
    Port Area (sq in) 15 24 40 64
    Port Length (inches) 19 16 16 16
    Woofer Diameter 8" 10" 12" 15"
    Free Air Resonance
    30 Hz 27 Hz 25 Hz 24 Hz
    Qts 0.816 0.619 0.608 0.799
    Qes 0.911 0.668 0.657 0.880
    Qms 7.795 8.377 8.275 8.773
    Vas 3.337L 12.510L 55.810L 102.00L
    Sensitivity 85.5 dB 86 dB 87 dB 89dB
    Shipping Weight 16 lbs 16 lbs 17 lbs 21 lbs
  13. #33 Re: How Hard To Hit
    Jul 2008
    keep in mind these subs took 70% of the trophies at the world finals this year.
  14. #34 Re: How Hard To Hit
    Feb 2009
    Virginia
    Glad to see some experience chiming in. The efficiency of those speakers says volumes about their design for SPL. 500watts is a ton of power. People don't seem to realize that these days. You can cause ear damage with a good clean 5 watts.
    Throw in those DD's and you might have fixed your power problem Matter of fact...trade in that kicker for a sundown audio SAZ-1000d or so. I've heard some people switching over(from kicker) had cleaner, louder speakers and the head light dimming was gone. Electricity is a neat thing.
  15. #35 Re: How Hard To Hit
    Feb 2009
    Virginia
    Food for thought. A smaller driver with the capacity for more excursion can hit higher frequencies(20hz to 30hz or so) better vs. a larger driver with more surface area but less excursion.
  16. #36 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    it would just be hard for someone like me who's such a fan of kicker to switch brands. It's like saying GM is gone, i'm going to ford
  17. #37 Re: How Hard To Hit
    Nov 2008
    Hauppauge, NY
    Good Choice in the ford my friend!! lol Kicker is good, but not the best, i had two JL W3's that hit harder than my friends system with two kickers, JL is a much better sub, one guy i saw got three W6's installed in his bronco, why i dont know, he got a whole system, deck, the three subs and speakers, he came back saying his deck wont stop skipping, the tech looked at him and said well you wanted 3 JL's what did you expect lower your bass, and the W7 is an AMAZING sub, one 12" W7 will blow your trunk lid clean off, they have one in a box in the high end room, the whole building shakes
  18. #38 Re: How Hard To Hit
    Aug 2008
    Fayetteville, NC
    you guys feel this strongly that DD is better than kicker? i'll do some research on DD but i'd go alil bigger than those 10's
  19. #39 Re: How Hard To Hit
    Nov 2008
    Hauppauge, NY
    JL!!!!!! You will never look at another sub,
  20. #40 Re: How Hard To Hit
    Jul 2008
    DD is better than JL. Ill get some video of my 2 10's by tomorrow. look around on youtube search for DD u will see what they can do.these subs are HANDMADE in america.u cant go wrong.
  1. Hard Shifts.
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2009, 09:18 PM
  2. Never laughed so hard!!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 01-27-2009, 12:53 AM
  3. How hard to fix???
    By duane9586 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2009, 02:56 PM
  4. How hard is it to....
    By GTP4 in forum PCM Tuning
    Last Post: 10-27-2008, 08:30 AM
  5. HOW to and is it HARD?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-10-2008, 10:37 PM
