2 issues...one the powerbastrds link doesnt work, and the 220amp alt, is not listed for 06 model...but most engine componets are the same, think it will still fit?
and it is kinda a wiring nightmare, lol here is two pics...
I don't know how you feel about pre-fabbed?
Dual Solo-Baric L5 & L7 Subwoofer Boxes & Enclosures | Sub Woofer Box | Klaus Audio
I don't even know if those things match up with your speaker requirements. Some companies just slap things together and call it "good". Email kicker for specific box size requirements. Sealed will be much smaller and my preference since it's closer to accurate.
I never did really look into the wire diagrams for monsoon sound systems but I have a feeling that since you are going to use a CDA-9887 then you have the capability to tune into whatever the speakers like. If you have passive cross overs for them then dont' worry about active tuning at all. Leave all RCA outs at full range except for subwoofer. Cut that kid off around 70 or 80hz.
Oh...if it turns out your speaker enclosure is too small then you can throw in some poly-fill to help create more resonating space for the speaker. If your box is too big just throw in a 2x4 or so to fill the air space.
I just realized too. The picture of your box...only one speaker is running. Is that because of the head lights dimming?
nah I have the 2 subs wired together in series, inside the box. cause they're 4 ohm speakers, so I wired them down to 2 ohms. I bought myself alpine 6.5's and 6x9s and alpine 9887, now I just gotta wait til i get home to install them ...
if u look at the first pic, if u notice inside the ported hole, u can see the wires where their wired together
you want a hard hit, Screw Kicker, get 1 JL W7, and invest in sign language classes.
what rms are those DD's running at a piece??
heres the website and here is the specs on the subs i have..i have the lower end model but they still expensive as hell for bein 10's.i can only imagine what the other models can do.
http://www.ddaudio.com/dd/default.asp
SPECIFICATIONS
Series 1500
Voice Coil Diameter 2.0"
Magnet Weight 120 oz
Power Handling RMS/Peak 500/1800
Suspension 55 mm
Nominal Impedance S4.0 Ohm / D4.0 Ohm
DC Resistance 3.4 Ohm
Model 1508 1510 1512 1515
Rec Box (cubic ft) 1 1.5 2.5 4
Port Area (sq in) 15 24 40 64
Port Length (inches) 19 16 16 16
Woofer Diameter 8" 10" 12" 15"
Free Air Resonance
30 Hz 27 Hz 25 Hz 24 Hz
Qts 0.816 0.619 0.608 0.799
Qes 0.911 0.668 0.657 0.880
Qms 7.795 8.377 8.275 8.773
Vas 3.337L 12.510L 55.810L 102.00L
Sensitivity 85.5 dB 86 dB 87 dB 89dB
Shipping Weight 16 lbs 16 lbs 17 lbs 21 lbs
Glad to see some experience chiming in. The efficiency of those speakers says volumes about their design for SPL. 500watts is a ton of power. People don't seem to realize that these days. You can cause ear damage with a good clean 5 watts.
Throw in those DD's and you might have fixed your power problem Matter of fact...trade in that kicker for a sundown audio SAZ-1000d or so. I've heard some people switching over(from kicker) had cleaner, louder speakers and the head light dimming was gone. Electricity is a neat thing.
Food for thought. A smaller driver with the capacity for more excursion can hit higher frequencies(20hz to 30hz or so) better vs. a larger driver with more surface area but less excursion.
it would just be hard for someone like me who's such a fan of kicker to switch brands. It's like saying GM is gone, i'm going to ford
Good Choice in the ford my friend!! lol Kicker is good, but not the best, i had two JL W3's that hit harder than my friends system with two kickers, JL is a much better sub, one guy i saw got three W6's installed in his bronco, why i dont know, he got a whole system, deck, the three subs and speakers, he came back saying his deck wont stop skipping, the tech looked at him and said well you wanted 3 JL's what did you expect lower your bass, and the W7 is an AMAZING sub, one 12" W7 will blow your trunk lid clean off, they have one in a box in the high end room, the whole building shakes
you guys feel this strongly that DD is better than kicker? i'll do some research on DD but i'd go alil bigger than those 10's
JL!!!!!! You will never look at another sub,
