Remote Lock and Unlock Confirmation
With the remote lock and unlock confirmation feature,
you can program your vehicle to do the following:
When you use the remote keyless entry transmitter
(if equipped), to unlock your vehicle, your
headlamps will flash briefly to let you know the
command has been received. If you press LOCK on
the remote keyless entry transmitter again within five
seconds, the horn will sound briefly and the
headlamps will flash briefly to let you know your
vehicle is locked.
to unlock your vehicle, your headlamps will flash
briefly to let you know the command has
been received.
To customize these features to your preference,
see “Programmable Modes.”
Programmable Modes
Your vehicle can be programmed to one of the
following modes.
Mode 1: Both Features Off (Remote lock and unlock
confirmation are disabled.)
Mode 2: Exterior Lamps Flash Only
Remote Lock Confirmation: When you use the
remote keyless entry transmitter to lock the vehicle,
the headlamps will flash briefly to let you know the
command is received.
Remote Unlock Confirmation: When you use the
remote keyless entry transmitter to unlock the
vehicle or open the trunk, the headlamps will flash
briefly to let you know when the command
is received. Mode 3: Exterior Lamps Flash and Horn Sound
the horn will sound briefly and the headlamps will
flash briefly to let you know the command
is received.
briefly to let you know the command is received.
Mode 4: Exterior Lamps and Horn Sound
(on second LOCK press only)
command is received. The horn will sound briefly
and the headlamps will flash briefly if you press the
LOCK button again within five seconds.
When the vehicle is shipped from the factory, it will be
in Mode 4.
To change the mode do the following:
1. Follow the instructions for “Entering Programming
Mode” listed previously.
2. Press the LOCK button on the remote keyless
entry transmitter.
3. Count the number of chimes you hear. The number
of chimes tells you which mode the vehicle is set for.
You change the mode by pressing LOCK on the
remote keyless entry transmitter again.
4. Repeat Step 2 until you hear the number of chimes
that matches the number of the mode you want.
The mode you selected is now set. You can either exit
the programming mode by following the instructions
earlier in this section or program the next feature
available on your vehicle.
