Thread: audio 02 grand prix
Results 1 to 20 of 29
  1. #1 audio 02 grand prix
    SE Level Member jillandjesses02's Avatar
    Green Bay, WI 5430
    Does anyone know how to bypass the OEM stereo amp?
    also what is the best way to seal my 6X9's from the sub pressures in my trunk?
    Are the oem component speakers in the front doors 5.25" and 1" tweeters?
    Thanks for all your imput
    Jesse&Jill JLsubs Infinity components
  2. #2 Re: audio 02 grand prix
    SE Level Member bloxmagic's Avatar
    Oct 2008
    Carmel
    if you car came stock with the Bose stereo system then yes you will need to bypass it. The best way to do that is with the PAC OEM-2 adapter. If you don't have the Bose system then you might want to check your connections. Hope that helps!
    Front speakers
    Front Door: 5-1/4"
  3. #3 Re: audio 02 grand prix
    Green Bay, WI 5430
    The stock radio was a delco, could the components still be a bose? How do i know the difference? Thanks!
  4. #4 Re: audio 02 grand prix
    GTP Level Member dstout's Avatar
    ky
    Quote Originally Posted by jillandjesses02 View Post
    My front speaker grills still say "Bose" I never did change those, my amp is a little black thing mounted to the top of the trunk you see it as soon as you open the trunk lid not sure if it says bose anywhere on it I'll look later. My receiver was a Delco also but did not have any EQ settings.
    Hope this helps
  5. #5 Re: audio 02 grand prix
    Oct 2008
    Carmel
    you would know it would say on the car and would have the amp in the back just like dstout said
    '00 Fire Engine Red GT Sedan - PCM Tuned, 180* T-Stat, FWI, 70mm Throttle Body Adapted, MSD Coil Packs, MSD Ignition Wires, AL 605 Plugs, Coated Headers (New Headers Soon), 145 amp high output alternator, 2 12" Kenwood Subs, Alpine PDX1.1000 , Alpine Type R Speakers, Alpine HeadUnit
  6. #6 Re: audio 02 grand prix
    ky
    So do you guys have a Bose?
  7. #7 Re: audio 02 grand prix
    Oct 2008
    Carmel
    yea if you have the Bose system you will need to do a little more work
  8. #8 Re: audio 02 grand prix
    Stevens Point
    Uncalled for. Post removed. Infraction given.
  9. #9 Re: audio 02 grand prix
    Stevens Point
    Uncalled for. Post removed. Infraction given. 2nd infraction given.
  10. #10 Re: audio 02 grand prix
    GT Level Member flash527's Avatar
    Indianapolis, IN
    ^ wtf?
    04 GTP - FOTB, Intense PCM, 180* Thermo, SLP Headers, 3.4" ZZP Modular Pulley, Moroso Race Wires, 104 Plugs, TEP trans: 3.29's, Thrasher shift kit. Soon to come: 13 inch dual piston brakes, rims and tires, wideband tune by PRJ.
  11. #11 Re: audio 02 grand prix
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    a mod needs to clean that up
  12. #12 Re: audio 02 grand prix
    Apr 2009
    Wausau, Wisconsin
    is going on here?
  13. #13 Re: audio 02 grand prix
    Dec 2008
    chicago,illinois
    *removed the offending quote*
    Thanks for understanding.
    wtf
    going low on 20"
  14. #14 Re: audio 02 grand prix
    Apr 2009
    Wausau, Wisconsin
    Good ol' boys from Wisconsin I guess?
  15. #15 Re: audio 02 grand prix
    OEM tweet is probably around an inch, woofer is 5.25".
    The rear 6x9s shouldn't be running in the first place unless you have the level low enough that they don't deafen the rear passengers and so that they dont distract your ears from the front speakers.
    The sub should be firing into the cabin so that you don't have wasted sound pressure bouncing around the trunk instead of the cabin where it belongs.
    The problems you have are simpler to fix than you think.
  16. #16 Re: audio 02 grand prix
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    the factory tweeter is a 3/4 inch , i put memphis m class tweets in mine and they fit great , as for letting the pressure on the 6x9 take the rear deck cover off and just take the 4 inch speakers out totally , they dont put out much and it lets the bass wave hit the rear glass and give you about a 3 db gain as opposed to doing nothing and 3 db is a decent amout and it will keep the pressure off the 6x9 .... ill put it this way , works great for my jl 15w3 with a true 1100 watt amp breathe
  17. #17 Re: audio 02 grand prix
    Quote Originally Posted by eddie97gt View Post
    You're actually creating a bandpass enclosure by doing that and thats not a good thing.
  18. #18 Re: audio 02 grand prix
    Feb 2009
    Virginia
    Bad case of VBA huh?
    If you want accurate without a lot of headache find a place to build a box and request a Qtc of ~.7
    If you want band pass or ported, give them an idea of what you're looking for and see what happens. "Violent Bass Air" shouldn't be an issue. Think of it as an exaggeration for "what if" in poor installations.
  19. #19 Re: audio 02 grand prix
    Feb 2009
    Virginia
    What about Infinite Baffles?!
    IB Grand Prix Setup - DIY Mobile Audio
  20. #20 Re: audio 02 grand prix
    Quote Originally Posted by I800C0LLECT View Post
    IB's are supposed to be completely sealed and the enclosure for the back-wave is supposed to be rigid enough to not rattle to **** when you actually play some music. Sadly a car's trunk isn't designed to do that so you'd end up with sub par results.
    In home audio, its not that big of a deal because you have closer to 10 times Vas instead of car audio where you struggle to achieve 4 times. In the example you showed me, Vas is 281.8 PER woofer... The average trunk is around what, 300-400 litres? That falls a tad short of FOUR times the Vas of 2254.4 litres. 4 times is considered the min, 10 optimal.
    Also if you consider a car has a stupid bass enhancing "room gain" curve then a sealed box should be all you really need...
  1. Grand prix
    By MICHAELPIGEON in forum General Tech Discussion
    Last Post: 04-10-2009, 07:48 PM
  2. Help with 99' Grand Prix
    By Tomsecks in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-27-2008, 04:17 PM
  3. LS6 in Grand Prix
    By Ryan D. in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:58 AM
