Thread: Tweeter Installation
Results 1 to 10 of 10
  1. #1 Tweeter Installation
    Donating Users Burgundyman's Avatar
    Has anyone had luck installing tweeters in the original location just at the corner of the door...My 1998 GTP does not seem to have enough room to accommodate a replacement...I am looking at installing some 5.25 infinity kappa component systems...Any insights would be appreciated.
  2. #2 Re: Tweeter Installation
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    You should always have the tweeters within 6" from the woofer anyway so just surface them on the door panel if you can. That's how I always did it anyway.
  3. #3 Re: Tweeter Installation
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    I believe the best position for the average listener is in the middle of the factory mid grille, right in front of the midrange speaker. While this setup is debatable, I find it easy to do and has really good imaging.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  4. #4 Re: Tweeter Installation
    alhambra, Il
    Quote Originally Posted by VinnieGTP View Post
    While it is well known w/ people that it "has" to be w/in 6 inches of the midrange, this is very debatable. Especially since people who have won multiple sq competitions has tweeters in the a pillars and/or top of dash with the sound bouncing off the windshield.
    Steven Oliver
  5. #5 Re: Tweeter Installation
    Saraland Alabama
    I have mine in the stock location, I played with the mounting, and that was the only way to get the image up above my lap (my wife and I are both fairly short so our legs block the sound down low)
  6. #6 Re: Tweeter Installation
    SE Level Member nathan kilburn's Avatar
    Jul 2008
    georgia
    i had cut a hole in the door panel to put my tweeters in because i had the same problem you did and it came out to be very nice looking and when i was looking online at the 08 grand prix and i saw the component system it has in it with the tweeters right next to front speaker that is what mine looks like
  7. #7 Re: Tweeter Installation
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    stock location is the worst spot. The sound waves bounce off dash to windsheild and dash ect.
    Best is if tweeter is aimed at your ear
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  8. #8 Re: Tweeter Installation
    Saraland Alabama
    Quote Originally Posted by Toofastgs View Post
    mine is aimed at me in the stock location (made a couple of modifications though)
  9. #9 Re: Tweeter Installation
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I have had them in just about every position you can think of over the years and my honda prlude and these are prolly the best yet. But I also use time alignment so that helps too. 100_0715.jpg
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  10. #10 Re: Tweeter Installation
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by s1795so2 View Post
    i agree ... A pillar is a great place for tweeters... easy to run wire and easy to mount
