Is the only possible fix to get a new cluster? The check engine light does not come on when you turn the key.. or start it..
anybody with any thoughts? i can't find much info about this anywhere!!
Try changing the light bulb behind where the display is on the dash.
is it soldered in? I was able to pull a code DTC P0650 Malfunction Indicator Light (MIL) control circuit.. could that be because of a bad bulb?
Nope you just grab the plastic ''knob'' and twist. Then replace the buld. Yes that sounds like the problem for that code that was stored.
thanks man, i'm totally new to these cars so I have a lot to find out.. i do like to post the solution.. that sounds like it should be it, just a dead bulb.. so i'll be back to say if that worked or not (replacing the bulb).. at least I found why my air pump wasn't working.. blown fuse! hah
Yeah I hear ya... We also like to hear the solution to the fix also. So be sure to let us know.
fixed.. just a blown bulb.. onto the next thing.
Awesome.
Good to hear! More problems await you down the road... J/K These are awesome cars and will last forever as long as you take care of them.
yeah hopefully i dont run into too many problems.. seems like everybody that owns one loves it.
