I have an 04 GP Comp G and ive installed a Prestige APS-920 alarm/remote start/keyless entry system. everything works except when i hit unlock/disarm on key fob it disarms the system nut wont unlock the doors. I believe i have it wired to the right wire ar bcm because if i take the lock wire from alarm and hook it to unlock wire at bcm it unlocks. So i tried hooking the unlock wire from alarm to lock wire at bcm and nothing. so i checked the voltage at both lock and unlock wires coming from the alarm, thinking one wasnt working at all, and both had same voltage output when key fob was pressed. is there a setting in not seeing? do i need a relay? thanks in advance, you guys are awesome
BTW i have to use my factory fob to unlock doors so i have to carry both fobs which stinks!
