Thread: HVAC blower issues, intermintent gauge reading loss and charging system failure alert
Results 1 to 6 of 6
  1. #1 HVAC blower issues, intermintent gauge reading loss and charging system failure alert
    Jul 2017
    macomb mi
    hey everyone back to the drawing board again today after not having any heat blowing this cold morning. just to give a background the heat did the same thing a couple of months ago it would intermittently shut off and on every couple days it being off for only 5 min max then one day just shuts off completely blower and resistor were brand new at the time so I changed the control unit on the dash and it fixed the issue maybe 2 months later today same symptoms were happening then bam no heat on my 30 min drive due to the blower not blowing. also id say once every 20 to 30 cold starts ill get to my car and see none of the gauges are working and the T/C light is on. shutting off the car for 10 to 15 sec fixes the issue but this does not work for the heat sadly. also gunned it getting onto a main road today and got a charging system failure warning car runs fine and didn't do anything weird when the light flashed on but im sure its a symptom.
    alternator is a refurbished unit only a year or two old and battery is only a year old im thinking I have terrible grounds and was thinking of trying to do the big 3 upgrade but wasn't sure if its a good Idea and I don't know exactly what to do with it.
    let me know what you guys think id hate to have to get rid of this thing after how perfect its running and how fun it is for something silly like this but I don't want to be fixing my heat every 2 months either haha
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  2. #2 Re: HVAC blower issues, intermintent gauge reading loss and charging system failure a
    Apr 2015
    Columbus, OH
    Have you looked for a bad ground?
    Top Swapped 01 Imp
  3. #3 Re: HVAC blower issues, intermintent gauge reading loss and charging system failure a
    Jul 2017
    macomb mi
    not sure where all the grounds are ive redone the two under the headlights before though and they were trash when i did them and probably trash again im sure all the grounds are bad car is a rust bucket lol to give perspective radiator support straight fell out from rust rad is currently held by a lot of quality strategically placed zip ties haha. partially why I wanted to do the big 3 mod I know its not necessary and people say it would be easier to fix the bad grounds but I don't want to have to keep fixing grounds every 20k miles lol id rather do a end all fix even if it cost a bit extra.
    also heat has been turning on and off last night and today no correlation with anything that I can find so I feel like that seals the deal as it being bad grounds
  4. #4 Re: HVAC blower issues, intermintent gauge reading loss and charging system failure a
    Jul 2017
    macomb mi
    Just wasted my whole weekend did the big 3 upgrade nothing checked all the grounds theyre clean now even found a melted connector that I fixed and it worked momentaraly then put in a new blower and it worked for a bit but now its not working I dont know what to do anymore also have 3 different control modules that arent fixing anything
  5. #5 Re: HVAC blower issues, intermintent gauge reading loss and charging system failure a
    Jul 2017
    macomb mi
    I'm at the point where I just need to wire this fan directly to the battery with an on off switch whats the best way to do that??
  6. #6 Re: HVAC blower issues, intermintent gauge reading loss and charging system failure a
    Jul 2017
    macomb mi
    anyone know where ground g201 is looks like it may be the problem since i have other components that went out that are connected to that ground but its wierd all the wires going to the switch are fine and are either grounded or give voltage and the issue seems to be that the resistor is not getting voltage from the grey black wire when the switch is on so I would assume the switch is bad but I have 3 different switches and none of them work?
  1. Charging system failure
    By michaelbig in forum General Grand Prix Discussion
    Last Post: 09-03-2016, 04:17 AM
  2. Charging System Failure
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 08-14-2014, 11:35 AM
  3. Volt gauge reading high, "charging system failure"
    By Aeroheadcww in forum General Tech Discussion
    Last Post: 05-21-2014, 12:03 AM
  4. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
