Thread: is it worth the trouble
Results 1 to 10 of 10
  1. #1 is it worth the trouble
    Feb 2018
    texas
    to put 6.i inch component speakers in the door versus 5.25's...I would like more front stage....Can anyone recommend some decent ones of either size under 90 dollar...Cruchfield has a set of Memphis Audio 15-SRX6C that are opened, or scratched for a good discount...Any ideas..The ones in my doors now are junk... Memphis Audio 15-SRX6C
  2. #2 Re: is it worth the trouble
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I'm using some 6.5 infinity components. Had to trim the housing some to modify them to fit, but not bad. They sound great compared to what was there. That being said, I got them for $10 at the junkyard (someone messed up not seeing those there). I never buy audio equipment new personally. I always use facebook marketplace or craigslist. Someone is always going broke and needing money or just upgrading because they want something better. That's just my 2 cents though.
  3. #3 Re: is it worth the trouble
    Feb 2018
    texas
    Quote Originally Posted by wstefan20 View Post
    So can you briefly tell me about the install...I think I really want to run the larger fronts versus the 5.25..Thanks, and congrats on the awesome find...
  4. #4 Re: is it worth the trouble
    Nov 2011
    NY
    Can't talk about cheap... Unless picked up used as noted above. It's like modding the car to begin with, you don't get "good" with "cheap"... They are mutually exclusive!
    I'm running Boston acoustic separates in the front, infinity kappa in the rear, kicker amp and audiophile head unit that is amazing! But it wasn't cheap, and it didn't break the bank either
    Good luck with your search!
  5. #5 Re: is it worth the trouble
    Feb 2018
    texas
    Well my bank budget is about $100 for the fronts at this time...Give or take a couple of dollars...Options im considering..
    1. A better set of 5.25 coaxial....
    2. A set of 5.25 Separates..
    3. A set of 6.5 Coaxial...
    4. A set of 6.5 Separates..
    I dont mind a little door hacking....Just want a bit louder (and better sounding) Fronts....Not always in the car, some times I listen in the Drive, or the beach....Im old, and my hearing is not what it used to be, so top shelf stuff makes no sense to me....Thanks for any input on this guys...
  6. #6 Re: is it worth the trouble
    Aug 2017
    Raytown, MO
    Quote Originally Posted by gallileo60 View Post
    I should have some pictures on my home computer. All I did was cut the "collar" on the door piece, use a dremel tool to cut back the hole diameter and then run some screws down and it fit like stock. Nothing fancy. It will depend on the dimensions of the rear of your speaker that will determine how much you have to cut. I'll try to post some pics later.
  7. #7 Re: is it worth the trouble
    Aug 2017
    Raytown, MO
    I had a set of pioneers that were cheap components and I noticed a huge difference in the highs and the soundstage when I switched to the infinities. You should be able to pick up some cheap ones local on craigslist for that. Though, I've had some really good luck with the junkyard before. I even found a set of mbquart z series in there once. Just look for the ricer cars with "go-fast" stickers and fake looking stuff on them. They're usually the ones with good speakers strangely.
  8. #8 Re: is it worth the trouble
    Nov 2011
    NY
    Louder isn't always better... And sometimes louder is inversely proportional to quality. I don't think you're going to get "quality" separates for the front for $100 unless used. I think my Boston Acoustics were on sale at Crutchfield when o got them and they still tipped the scale at $150... For real quality the crossovers aren't going to be junk and the speakers will have some decent mags.
  9. #9 Re: is it worth the trouble
    Feb 2018
    texas
    considering whats in there now, just about anything is going to be a step up....not to mention my hearing is pretty well gone Sound Engineer for a band for about 10 years, and worked for a newspaper for 25, back then no osha to make you wear hearing protection, so none of us did.....Just looking for some ideas...thanks to all for the replies
  10. #10 Re: is it worth the trouble
    Feb 2018
    texas
    ended up getting Jl audio TR 650 CS, hope they work out well...
  1. General consensus on keeping steering wheel controls? Easy?/hard/worth the trouble?
    By jeighty3 in forum Audio, Security & Visual Electronics
    Last Post: 05-06-2012, 12:41 PM
  2. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
  3. What's it worth? 98 GTP
    By gypsyjon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2010, 06:09 PM
  4. I know its worth it, but is it really necessary???
    By sdavis11b in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2010, 05:49 AM
  5. This car is more trouble than it is worth
    By GothicWhiteTrash in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 11:36 AM
