Well, I'm attempting to bench test an 04+ base radio and so far have been unsuccessful. Here's the pinout I have, and I'm not sure what is correct.
Purple writing is for other gm stereos that use the same plug and aren't used on this radio.
Highlighted parts I have wired to battery. 15Amp fuse on B1 and 5Amp on B4 just to be safe.
CD player makes the "turn on noise" and the lights on every other bulb turns on. Haven't hooked up a speaker yet so that's next. There's absolutely no backlight or display even dim.
When I took the radio apart, I noticed all three bulbs were burnt out so I replaced them and tested the bulbs both out and after installation.
Pretty sure this radio is toast, but I figured I'd post this before I get a new one a screw it up too.
And yes, I have to bench test because I only own a 2002 so....
