Thread: Can't remove key without using the manual release
Results 1 to 4 of 4
  1. #1 Can't remove key without using the manual release
    Mar 2016
    Philadelphia
    2002 GTP, 139K miles in great shape, just recently the key would not go all the back to removal position & the DIC went dark. After reading a ton of threads I've:
    • check all fuses
    • checked all relays
    • replaced ignition switch
    • reset the computer
    • disconnected the battery for a few hours
    • removed the lock cylinder to see if anything was out of order
    All to no avail??? Any help would be greatly appreciated!!!
  2. #2 Re: Can't remove key without using the manual release
    under the column is a pop off button, you push a pencil or the likes up inside to free the key, that part is likely bad. you can roll up a business card or use a fat straw and cut it to length so it pushes the release button with the cap back on.
    directions for opening the column are in this link http://sparkys-answers.com/2009/09/2...-changing.html iirc the part is in the pics there too.
  3. #3 Re: Can't remove key without using the manual release
    Mar 2016
    Philadelphia
    Thx I can get it out manually by pushing the solenoid as you pointed out, I'm looking for a permanent fix, thx.
  4. #4 Re: Can't remove key without using the manual release
    Jul 2010
    Coquitlam,BC,Canada
    You need to replace or remove the park lock solenoid. I removed mine.
    http://chrisb.users.superford.org/Gr..._Solenoid.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Zip Tie Key Release Button
    By SubwayGuy in forum General Grand Prix Discussion
    Last Post: 04-19-2015, 06:33 PM
  2. Trunk release
    By Goy in forum Introductions/Noob Questions
    Last Post: 01-07-2013, 01:45 PM
  3. Key release
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-16-2011, 12:28 PM
  4. GTP-trunk release
    By PCTGTP in forum General Tech Discussion
    Last Post: 05-19-2010, 03:55 PM
