Thread: need to start a drive a parts car with no key
Results 1 to 20 of 20
  1. #1 need to start a drive a parts car with no key
    Sep 2016
    Western ky
    Haven't posted in a while guys. I bought a top swap for my 04 gt a while back then it went on the back burner for a while. Changed my game plan to turbo then ultimately decided to leave it alone due to poor boy status. Then I was presented with the opportunity to buy a 05 gtp loaded and in all mechanical soundness for $400. Only catch is theres no title and no key.
    I have to get it running to test all of the equipment and electronics I'm about to swap out of it and because pushing it around on my property with the steering wheel locked is impossible. So I'm stuck with a car that's been junked out of the system (siezed by tow yard for fees) so I have no way to prove ownership to a dealer to have a key cut. Sure a locksmith will do it but I'd still have to weasel the stealership into programming the chip to my car. And I'd rather not even spend money on a car and ignition switch that will ultimately get scrapped.
    So now that I've explained myself maybe I can ask the next couple questions without looking like I'm trying to steal a car lol.
    1. I found a YouTube video where a guy shows a 30 minute learning process with 3 10 minute ignition cycles to mate a new chip to his 04ish impala with no other key as a master. He claims it can be done on all gms with that style key. It looked pretty legit in the video. Anyone ever done this?
    2. As for cutting the key... I'd rather break the ignition and use a flat head than waste money on a key. The drill method doesn't look real easy since it's flush mounted on the dash so would a slide hammer with a screw in attachment do the trick?
    3. Assuming I can now turn the ignition switch with a flat head and I can successfully program the chip in a blank key would taping the key over the little hole for the chip reader suffice?
  2. #2 Re: need to start a drive a parts car with no key
    SWPA
    Steering wheel doesn't lock on an 05 because of the key location. At least it didn't on my 07.
  3. #3 Re: need to start a drive a parts car with no key
    hangover park IL
    .... or you can reflash the PCM with Pass Key deleted and unbolt the ignition switch lock cylinder from the dash with three screws after popping the trim panel off remove the switch off the back of the lock and tumblers and you can turn it with your finger if I recall....boom you're done
    ~James~ Psychotic Gearhead
  4. #4 Re: need to start a drive a parts car with no key
    Sep 2016
    Western ky
    Either it's locked or someone has done some unnecessary welding lol. Wheel won't budge.
  5. #5 Re: need to start a drive a parts car with no key
    Sep 2016
    Western ky
    I have no way of reflashing. And would the key be required to release the lock cylinder from the switch?
  6. #6 Re: need to start a drive a parts car with no key
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    You can get the lock cylinder off of the switch without the key, but without the pass key chip the computer will disable the fuel pump. Sorry to say but without a title you don't own the car. The tow company should have filed paperwork for their lien with the county clerk that would have gotten the title transferred to them so that they could legally sell the car to you.
    Read HERE and scroll down to "repossessions".
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  7. #7 Re: need to start a drive a parts car with no key
    Sep 2016
    Western ky
    I'm very aware of this. Did you read my post? That's why I'm just going to learn the key myself.
  8. #8 Re: need to start a drive a parts car with no key
    Dec 2008
    ****'s Creek
    Interested to see if it works, Post back on how that goes.
  9. #9 Re: need to start a drive a parts car with no key
    Aug 2016
    CT/RI Border
    Red neck it together with toggle switches? Had a 99 Century that the chip reader had gone bad, and while it wouldn't start on its own, a flip to ON still allowed fuel/spark to occur. Flip the toggle for Starter and off you go.
    Sent from my ASUS_Z00TD using Tapatalk
  10. #10 Re: need to start a drive a parts car with no key
    Sep 2016
    Western ky
    I thought about toggles but I didn't want to get that complex. Figured there would be a lot of crap to rewire or become conplicated and I want to make sure I have full function with no security issues to test all the equipment in the car and run a scan tool to check kr... I'm going to try to learn a chip myself. Just got to get me a blank pk3 key. No dealer in the town I work in...
    I'll definitely let you guys know if it works. If it doesn't I found another alternative. There's a piggy back pass key bypass modual on amazon for like $35.
  11. #11 Re: need to start a drive a parts car with no key
    Dec 2008
    ****'s Creek
    Here's another process that may work: LINK
    You will have to get the lock cylinder off of the ignition switch so you can turn the switch without the key. At this point I wouldn't even worry about the key since you don't have one to copy and no dealer will cut a key from the VIN without the title. Sounds like it's going to the crusher anyways after you get the mechanicals out.
  12. #12 Re: need to start a drive a parts car with no key
    May 2016
    Burns City, Indiana
    Most JY wont take car without proof of ownership, simply go to local DMV and ask about paperwork to file for mechanics lein, technically you dont have to be a business, you could claim for several reasons I believe, you were cleaning car, swapping stereo parts, storing car. Most times it takes couple of certified leatters one to you then leave un opened, one to original owner. Set fees, bill price so high owner wont retrieve ir as they wouldnt retrieve it from tow yard so Id say your ok, then file papers. Takes time and bit of cash. Google mechanics lien or abandoned car titling. shouldnt be that hard. One thing is you may have to have state police come run it to prove its not stolen.
    One other possibility is dissasembly key cylinder and remove all the guts that key needs to ride in then simple new uncut key from dealer would suffice with 10 or 30 minute relearn. If you have the car and paid for it from tow company and recieved a reciept that should prove at least partially you own it. Good Luck
  13. #13 Re: need to start a drive a parts car with no key
    Dec 2012
    troll land
    No key no title I find another donor.....
  14. #14 Re: need to start a drive a parts car with no key
    Dec 2012
    troll land
    Seriously no reason not to have a title unless its hot, has a lein(still hot), or is hiding from repo men(yup still hot). All other situations there's still easy ways to get ownership paper even if not actual title.
  15. #15 Re: need to start a drive a parts car with no key
    Aug 2016
    CT/RI Border
    Quote Originally Posted by l67ss View Post
    Was going to say "ownership paper" instead of title is easy, but not always title. Many states in the North East stop issuing titles after 15 years old.
  16. #16 Re: need to start a drive a parts car with no key
    Nov 2011
    NY
    No title required upon transfer of ownership? Hmmmm... There's 15+yr old cars worth more than my house! You bet your ass I'm not paying unless a clear title is shown! Vin is a Federal Registry as well, and was instituted primarily for tracking "stolen" vehicles/parts, then for Safety (recalls). Bottom line is I wouldn't be in possession of a car, even if given to me for free, without a title/bill of sale!
  17. #17 Re: need to start a drive a parts car with no key
    Aug 2016
    CT/RI Border
    Quote Originally Posted by coolone View Post
    Yeah in CT/RI it's last Reg. and Bill of Sale to Prove transfer.
  18. #18 Re: need to start a drive a parts car with no key
    Dec 2012
    troll land
    In Georgia they won't issue a title for anything older than 1980 I believe. If not hot or no leins the dealer can get you a key
  19. #19 Re: need to start a drive a parts car with no key
    Dec 2012
    troll land
    Really tho on an 05 you really have to go out of the way to lose a title where it can't be replaced
  20. #20 Re: need to start a drive a parts car with no key
    Dec 2008
    ****'s Creek
    Did the OP ever get it running?
  1. all wheel drive drive rain with 3.8 engine
    By fisheson in forum General Grand Prix Discussion
    Last Post: 03-11-2016, 12:13 PM
  2. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  3. 1990 3.1 lit hard start/ no start. fuel pressure prob
    By wadd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2015, 07:22 AM
  4. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  5. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
