Thread: Fan Speed 5 Delay
Results 1 to 13 of 13
  1. #1 Fan Speed 5 Delay
    SE Level Member void33's Avatar
    Jan 2013
    Chicago
    Fan blower works great on all speeds except number 5 (highest). When I turn it to #5 it turns off, but then about 2-8 seconds later it turns back on on speed 5. So, there is some sort of delay there. Thinking it's a switch or solenoid somewhere. Any ideas?
  2. #2 Re: Fan Speed 5 Delay
    Normally it's to do with the blower motor resistor.
  3. #3 Re: Fan Speed 5 Delay
    Jan 2013
    Chicago
    Thanks for the advice, just ordered ACDelco 15-80571.
  4. #4 Re: Fan Speed 5 Delay
    GTP Level Member
    Oct 2014
    Let us know if it works. I have a similar problem where 5 does not work. Ever.
  5. #5 Re: Fan Speed 5 Delay
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I fought with my 03 winter beater/spare car's blower fan until I finally cut the wires at the fan, pulled key on power from fuse box, and ran wires to a simple toggle switch that I jammed between the glove box and center part of the dash. Pretty?...No. Adjustable speed?...No. (I tried to find a dial 12V resistor at like radio shack, but they didn't have it, so I gave up on that) Functional enough to defrost/heat/ and A/C ?...Yup.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  6. #6 Re: Fan Speed 5 Delay
    SWPA
  7. #7 Re: Fan Speed 5 Delay
    Quincy, Mass
    99.9% of the time it's the resistor, but it's not RadioShack resistor.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Fan Speed 5 Delay
    Jan 2013
    Chicago
    Okay I just replaced the resistor with this part (http://www.rockauto.com/en/moreinfo....359345&jsn=419) but it still does the same thing! Everything works, except on high speed it takes about 8-12 seconds to turn on the fan... Any ideas???
  9. #9 Re: Fan Speed 5 Delay
    Jan 2013
    Chicago
    Could it be the Blower Switch? I'm looking at RockAuto and that's the only other thing I see related to the blower motor other than the motor itself... (http://www.rockauto.com/en/moreinfo....0487&jsn=10487)
  10. #10 Re: Fan Speed 5 Delay
    SWPA
    You're going to have to some diagnosis. Test the power output at the plug to see what happens. If power is going to the fan properly then you may have a faulty/dying fan motor.
  11. #11 Re: Fan Speed 5 Delay
    Jan 2013
    Chicago
    I've had a breakthrough...
    I don't know why I didn't try this before. When I turn it to 5 (all the way up) and tap the knob or hit the knob the fan starts on full speed immediately! This leads me to believe it's the blower switch. Perhaps a short somewhere. Any objections or thoughts?
    New blower switch: http://www.rockauto.com/en/moreinfo....0488&jsn=10488
  12. #12 Re: Fan Speed 5 Delay
    SWPA
    Looks like a sound thought.
  13. #13 Re: Fan Speed 5 Delay
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    I replaced the blower motor resistor but was still having problems. It wound up being my ignition switch. If your day time running lights are out as well this is your culprit.
    http://sparkys-answers.com/2009/09/2...-changing.html
  1. 2005 GT 5 second delay for lock/unlock with keyfob
    By Bigfoot365 in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2013, 01:38 PM
  2. headlight delay feature
    By iamjeff69 in forum General Tech Discussion
    Last Post: 11-06-2010, 12:37 AM
  3. Display Delay at Start Up
    By darinparsons99 in forum General Tech Discussion
    Last Post: 11-12-2009, 11:52 AM
  4. Auto delay headlights?
    By Carbon Summit in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2009, 11:33 AM
  5. Exterior Lighting Delay Question
    By brian0488 in forum General Tech Discussion
    Last Post: 02-13-2009, 09:01 PM
