I did some looking around, so apologies if this is easily found and I just missed it.
I just obtained a 2004 Comp G with the Monsoon system. It has the center channel, which is fortuitous because I run a 5.1 channel 2-din unit that I play DTS/Dolby 5.1 discrete music on. I need to know if the Monsoon system will allow me to run the amp outputs directly to the speakers (if I need to put new speakers in that's OK, I realize they may be a different impedance) or directly to the amp (as the Bose system in my '02 does) to interface with? From what I'm reading, the Monsoon treats each channel seperately. Am I able to run wires to these?
