MrDavid, any recommendations for a fuse to put it on in the interior fuse panel?
Just an aux port
The sunroof fuse is fine, if you are concerned about the amperage draw, get a relay and run a power wire with an inline fuse to the battery for auxiliary power and just use the sunroof fuse as a switch to turn the relay on.
I tried searching, but other than just text can anyone find an actual picture (drawing pic) or the pin out and plug style?
This is the info I have so far:
2006 Pontiac Grand Prix Factory Stereo Install Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Run a wire from the back of the radio to the steering column or fuse box for a switched power source.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Violet
Car Stereo Amp Trigger Wire: Violet
Car Stereo Amplifier Location: Located under the center of the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Best of luck on the hunt. I still haven't found it. If you do find one please post it.
