Thread: Which factory cam for a budget DOD delete?
Results 1 to 11 of 11
  1. #1 Which factory cam for a budget DOD delete?
    N. Cambria,PA
    I am rounding up parts for a DOD delete on my '06 GXP. I am on a tight budget,so I am going to go with a used factory camshaft. After some research the LS2 cam looks like it would work well. The car is a daily driver and I will be using the factory torque converter. I will eventually be doing an LS1/LS2/LS6 intake swap,LS3/LS7 TB,LS7 MAF,etc. Is this cam a good choice for my application/budget? Thoughts?
    2006 Grand Prix GXP,silver,charcoal int,CAI,magnaflow catback,diablosport predator.
  2. #2 Re: Which factory cam for a budget DOD delete?
    Arizona
    Ls2 all the way
  3. #3 Re: Which factory cam for a budget DOD delete?
    N. Cambria,PA
    Cool. I guess the search is on to find an LS2 cam then. Thanks for the reply.
  4. #4 Re: Which factory cam for a budget DOD delete?
    I figured a first gen Z06 (LS6) cam wouldn't be a bad choice either.
    I know you can find them just as cheap.
  5. #5 Re: Which factory cam for a budget DOD delete?
    N. Cambria,PA
    Blueguy that is true. I think the specs on the first gen LS6 cam are about the same as the LS2. LS2 cams seem more plentiful on craigslist,etc. Hopefully I can find one for a good price.
  6. #6 Re: Which factory cam for a budget DOD delete?
    Just for info sake...
    LS2: 204/211 @ .050" .525"/.525" I/E max lift, 116 LSA
    LS6: 204/218 @ .050" .551"/.547" I/E max lift, 117 LSA...which means its a smidge smoother too, lol.
  7. #7 Re: Which factory cam for a budget DOD delete?
    Approved Vendor FurchesPerformance's Avatar
    Jun 2014
    Springfield MA
    LS2 is an excellent choice to get you started. Obviously when the heads are off, pop a new set of LS9 springs on (they have superseded the LS6 part number).
    If you need lifters, trays, gaskets, head bolts and etc...I would be happy to fire off pricing on a package deal of the parts. Not sure what you already have.
    Brandon
    Furches
    2008 -Dark Slate Metallic- Grand Prix GXP
    2005 -Dark Cherry Metallic- Grand Prix GXP
    2005 Monte Carlo SS Supercharged
  8. #8 Re: Which factory cam for a budget DOD delete?
    N. Cambria,PA
    FurchesPerformance I will keep that in mind if I need any parts. Thanks.
  9. #9 Re: Which factory cam for a budget DOD delete?
    Arizona
    All u need to know is here ls6 cams never performed as good on the 5.3 for whatever reason. Granted there testing it with a truck intake and different heads.
    http://www.hotrod.com/how-to/engine/...st-comparison/
  10. #10 Re: Which factory cam for a budget DOD delete?
    I was under the assumption it was all in the heads, as the intake manifold flows just fine on the trucks...where the manifold for us would be the limitation there.
    I'd venture to guess that the LS2 and the LS6 would make very similar numbers on a basic LS4 motor, even with an intake swap.
  11. #11 Re: Which factory cam for a budget DOD delete?
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    LS9 cam fits any LS4 and its just over $100 new. You lose some low end torque but strong top end
    Email all inquiries to willoverkill@gmail.com!
  1. 12 sec budget GTP
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 06-11-2013, 09:20 AM
  2. Baller on a budget?
    By Kolton Lock in forum Turbo
    Last Post: 01-21-2013, 09:03 AM
  3. Headers on a budget
    By chris99gtp in forum General Tech Discussion
    Last Post: 11-05-2012, 04:31 PM
  4. Perfomance on a budget?
    By jasonball in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 11:50 PM
