Thread: some cam info for thought *possible sticky*
Results 1 to 6 of 6
  1. #1 some cam info for thought *possible sticky*
    GTP Level Member joshv's Avatar
    canada
    **possible sticky****
    met up with will overkill for burgers and tuning ( a friends car ) and we talked about cams
    just in case anyone didn't know any 2005-2006 LS4 can use a LS9 cam
    P/N 12638427.
    the 2005-06 ls4's use 3 bolt cam gear which the ls9 cam is.
    the 2007+ is you use this part P/N 12586481 it will give you a 3 bolt came gear- or a ls3 cam is a single bolt cam
    in the 07+ ls4's use the Ls3 tensioner which has been proven less durable then the older ls2 style that the 05-06 ls4 use's. its not recomended to swith with newer ls4s but is an inexpensive part if you wanted to
    ls3/ls9 valve spring kit P/N 12499224
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  2. #2 Re: some cam info for thought *possible sticky*
    Nice little tid bit of info, Will knows his stuff.
    As soon as I figure out the best way to yank this LS4 out of this car, I'll probably be doing a cam swap over the winter.
    Pretty sure I'll be that guy and use a BTS3/4 cam in this thing. Uselessly huge cam for maximum noise.
  3. #3 Re: some cam info for thought *possible sticky*
    canada
    blueguy you pulling engine just to install cam ? can be done through wheel well aswell
    and yes will is a very interesting guy!
  4. #4 Re: some cam info for thought *possible sticky*
    Arizona
    I've posted it before but here's the most information so one can make a accurate decision
    http://www.carcraft.com/techarticles...n/viewall.html
  5. #5 Re: some cam info for thought *possible sticky*
    I should revive that LS4 overall mod thread that I started a couple years back.
    And Josh I'm not sure. I've got a buddy who's a huge LS guy with a built catfish...and he's done quite a few cam installs...plus he has a lift so I'm assuming we're just gonna lift the body off the powertrain.
  6. #6 Re: some cam info for thought *possible sticky*
    canada
    ^ ahh i see.. deff alot easier with hoist
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. first days!!! any info of good info
    By 97gtp83boy in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 02:17 AM
  3. sticky take off
    By 94grandprix in forum General Tech Discussion
    Last Post: 03-25-2011, 11:45 AM
  4. sticky this please
    By BoostJunki3 in forum Tires & Wheels
    Last Post: 03-21-2010, 02:44 PM
  5. Huge sticky!!
    By blueguy in forum General Tech Discussion
    Last Post: 07-04-2009, 08:38 AM
