Thread: Service abs/trac/stability mgmt light on
Results 1 to 19 of 19
  1. #1 Service abs/trac/stability mgmt light on
    GT Level Member sirricealot's Avatar
    Sep 2012
    Mascoutah IL
    It comes on randomly and usually goes away when I shut off car and start again. Wondering what everyone thinks it may be? I had a wire grounding on the manifold when I got the car that gave me all sorts of lights on and gm fixed it. I was thinking front wheel hubs? Sometimes when I'm stopping at slower speeds the brakes grind like abs kicks in or something. I have an extended warranty I'm gonna try to use just need to havr the $ set aside for what they don't pay. Was gonna take to gm In a few weeks. Any help is appreciated!!
    2008 Grand Prix GXP 5.3L V8 (DRUNYON)
  2. #2 Re: Service abs/trac/stability mgmt light on
    if you got a warranty, use it. it could be bad hubs, bad sensor in the hub, wires.
    the dealer will scan the car and track it down.
  3. #3 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    yeah ive got a feeling its a bad wire. it usually doesnt come on unless i hit a bump. honestly i love how it feels with the abs off and trac off lol. but i hate all the dash lights.
  4. #4 Re: Service abs/trac/stability mgmt light on
    if hitting bumps makes the lights come on, its a hub more then likely. or while turning and hitting a bump.
  5. #5 Re: Service abs/trac/stability mgmt light on
    Banned
    Jan 2013
    Colorado
    If the lights are on when the car starts what do you think that is?
  6. #6 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    Well lights arent on when i start my car. so im assuming that means it would be the wiring or a module. I don't care if its a hub as long as my warranty covers it lol. was gonna get front rotors replaced soon anyways. wonder how bad gm will rape me on those, or if i should go to my local auto shop for that. need 4 tires and a rear alignment(idk why its outta wack)
  7. #7 Re: Service abs/trac/stability mgmt light on
    hubs and abs repairs are covered under warranty, if you have one, aka FREE.
    If the light comes on when driving, or turning or hitting bumps its more then likely a bad hub.
  8. #8 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    I've got about 80k miles on the clock. GM warranty has been gone lol. I have an extended warranty. Im guessing its a bad hub, it keeps doing it almost everytime im driving now. its random when it comes on tho.
  9. #9 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    Had the shop look at it the other day. Thankfully I have that extended warranty and they approved the repair or I would be taking the car back to the bank. 2 Bilstein struts for the rear with mounting plates, front right control arm with balljoint, front right wheel hub. $2400... The bilsteins were $450 each through dealer direct. Glad I only have to pay $100 for the whole repair job!
    Also I'm getting 2 rear tires with 90% tread for $175 for the pair .
  10. #10 Re: Service abs/trac/stability mgmt light on
    Dealerships sure like butt rape people on prices for parts.
  11. #11 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    It's gettin done at a local shop I know the owner. The only place they were able to purchase the strut from was the dealer direct route. Bilstein strut was 450 a piece. Glad it didnt come outta my pocket. Always buy extended warranties!
  12. #12 Re: Service abs/trac/stability mgmt light on
    I live here. DirtDog's Avatar
    Jun 2012
    450 seems high. Their not even that much brand new for my gxp
  13. #13 Re: Service abs/trac/stability mgmt light on
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    gmpartsdirect.. 220 for rear, 300 for front. I got mine cheaper, but I can't for the life of me remember where I ordered them. Maybe I got a receipt laying around somewhere.
    2005 GP GXP Ivory White, OBX Headers, Cat and Muffler delete, HP Self Tuned, De-badged/Custom LS4 badges, K&N CAI, Intense Poly upper mounts, Strut Tower Braces, HSRK, HID 8000k headlights, Switchback LED front turn signals, interior LED's. Dyno'd @ 275whp/275wtq
  14. #14 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    The vendor they had to go thru, it's dealer cost pretty much. It's getting the tires installed in morning then a full alignment which warranty also covered :-). He said it drives so much nicer now that the parts are fixed.
  15. #15 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    Now the abs module is bad, $550. Warranty covers it :-). So it wasn't the wheel hub after all.
  16. #16 Re: Service abs/trac/stability mgmt light on
    thats why paying to get it scanned is worth every dollar. abs stuff is hard to track down if the obvious is not found.
    my abs light had been coming on randomly since i got the car. only when you first start it up and go. tripped the light 10% of the time.
    i changed my alternator 3 weeks ago and no more abs light since. the abs self check seems to be less loud too, and i dont feel it as much either.
  17. #17 Re: Service abs/trac/stability mgmt light on
    Sep 2012
    Mascoutah IL
    They are sending my abs module out to MA on Monday for rebuilt. Total bill is almost $3000 and all I have to pay is $321 :-). That's for two rear tires and a deductible from warranty. Always buy extended warranties!
  18. #18 Re: Service abs/trac/stability mgmt light on
    Donating Users
    Denver, CO
    Thanks for all the info. Had the same thing happen to my 07 GXP today. To the shop it goes in the AM.
  19. #19 Re: Service abs/trac/stability mgmt light on
    Nov 2015
    Ontario
    Isn't that the truth....
  1. Replies: 25
    Last Post: 01-26-2013, 11:52 PM
  2. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  3. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  4. Service "vehicle" soon, trac off and ABS light all on
    By 98RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 10:45 PM
  5. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
