Thread: LS2 Throttle Body Install
Results 1 to 20 of 21
  1. #1 LS2 Throttle Body Install
    Arizona
    EDITED: first off thanks to fieroguru, DavidGXP, and GXP25 for their research in this area the FSM GXP25 provided was the last unknown for this swap turns out my alldata Ls4 wiring diagram was wrong, so i deleted it out of the original post please disregard quotes of the orginal in posts mentioned below..
    Courtesy of GXP25
    **This is a general guide ALWAYS verify your year TB pinouts first**
    PINOUTS ARE AS FOLLOWS
    LS2 GTO TB . LS4 TB
    PIN A ---- PIN F
    PIN B ---- PIN E
    PIN C ---- PIN H
    PIN D ---- PIN A
    PIN E ---- PIN B
    PIN F ---- PIN D
    NOT USED PIN G&C ON THE LS4 HARNESS
    **If you have idle surge or hanging idle see below
    http://youtu.be/WI-RuRQ1nDc
    PARTS LIST:
    TB adapter here 55 USD http://www.alpermotorsports.com/inde..._detail&p=1688
    Pigtail: LS2 Throttle Body Pigtail Brand New LS2 TB Pigtail | eBay
    Throttle body: Ebay got mine for 140 shipped
    all bolts are m6 x 1.0 you will need 4 for the TB and 3 are included with the TB adapter to the intake manifold
    Thickness of LS2 TB for bolt length
    Adapter
    For issues with idle like i eventually had you will need to adjust 2 tables in the pcm
    ETC scaler and Base idle airflow need to be adjusted to get you idling right.
    here are the values i used with good sucess results may vary.
  2. #2 Re: LS2 TB install
    Dec 2012
    wichita,ks
    Any noticeable difference?
    It is just a FAMILY CAR
  3. #3 Re: LS2 TB install
    Arizona
    Quote Originally Posted by mudneck4 View Post
    kind of a unfair question the LS1 intake is worth 15hp alone its also ported and instead of a 75mm TB theres a 90 now so needless to say theres more involved then just the TB here. When i get it on this weekend ill update
  4. #4 Re: LS2 TB install
    Yoga city
    I'm loving this!
  5. #5 Re: LS2 TB install
    Dec 2012
    wichita,ks
    Didn't know the ls1 or I read over it lol... I heard the ls1 intake swap was a b!tch to so?
  6. #6 Re: LS2 TB install
    Dec 2012
    wichita,ks
    I can pick up a ls1 intake for 50$ so that's why I'm asking
  7. #7 Re: LS2 TB install
    Arizona
    If you can get a ls6 though i d get that But regardless the ls1 over the ls4 any day theres plenty of write ups though on ls1tech to get you through matter of fact nmp0098 has a writeup on this site iirc
  8. #8 Re: LS2 TB install
    Dec 2012
    wichita,ks
    Ill look into it. Might just be having one pop up friends going with a fast intake on his 00 camaro and he has a ls6 right now
  9. #9 Re: LS2 TB install
    Arizona
    Grab it and remember all ls6 intakes have a flat underside ls1's are curved
  10. #10 Re: LS2 TB install
    Dec 2012
    wichita,ks
    Be flat out honest I'm a ford guy at heart and the Prix grew on me!!! What's the difference between flat bottom and curved? Clearance issues? Flow issues?
  11. #11 Re: LS2 TB install
    Arizona
    Nah that's just how gm made them ls6 intakes are way better than ls1's intakes but I'm cheap and not in a hurry to get one yet.
  12. #12 Re: LS2 TB install
    I live here. DirtDog's Avatar
    Jun 2012
    btw i like your motivated fu*k yea at the end of the video...youd think you just made a major improvement or something on your car
  13. #13 Re: LS2 TB install
    Arizona
    Quote Originally Posted by marines542 View Post
    **** I was happy I sent blow up my pcm lol but motivated.... Hell yea lol
  14. #14 Re: LS2 TB install
    Jun 2012
    Do u remember the length bolts u ended up going with on the ls1 intake with the ls2 tb and all?
  15. #15 Re: LS2 TB install
    Arizona
    40mm. M6 bolts.
  16. #16 Re: LS2 Throttle Body Install
    Wichita
    I'm super late to the party I know. Soo with an '08 LS4 the LS2 TB is plug and play?
  17. #17 Re: LS2 Throttle Body Install
    Arizona
    For 08s use the ls3 gold blade they are about 130 brand new off Amazon Same wiring
  18. #18 Re: LS2 Throttle Body Install
    Wichita
    ^^^That's news to me. Thank you for letting me know!
  19. #19 Re: LS2 Throttle Body Install
    Wichita
    With an LS3 TB I lose the vacuum fitting that's on the LS4 TB. Where does it get moved to?
  20. #20 Re: LS2 Throttle Body Install
    Donating User
    Aug 2016
    MI
    I Had to drill and tap my TB adapter to fit a new fitting for the brake booster vaccum line. I used a 1/4 NPT with 1/2 dia. barded end.
  1. Detaching and Reattaching Throttle Cables to L67 Throttle Body
    By komrad36 in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2017, 12:09 PM
  2. MAF, IAC & throttle body
    By Nicolecc2 in forum General Tech Discussion
    Last Post: 09-01-2011, 11:12 PM
  3. No Throttle response after IC install?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2011, 01:28 PM
