Thread: LS4 gauge install question
Page 5 of 5 FirstFirst ... 345
Results 81 to 95 of 95
  1. #81
    I live here. DirtDog's Avatar
    Jun 2012
    Awesome. When ya get time id live some pics and where ya grounded it. I helped a friend do his with 2 gauge and we used a bolt on the tranny. Did u leave all the stock wires hooked up as well? And for the battery to alternator did u by chance use an inline fuse?
    Sent from my DROID RAZR using Tapatalk 2
  2. #82 Re: LS4 gauge install question
    Arizona
    Circut breaker is mounted behind the battery box in the trunk now. the battery is grounded to the trunk area. I bought a battery post and utilized the winshield wiper resoiver screw to install it there. That is where my battery + leads to and the factory wire for the starter is attached to. I then run another wire off the post to the fuse box where my alternator is also wired to. no issues for months now car runs great HID's never flicker and my voltage is running top notch...knock on wood... I took the time to scrape the paint off major ground connections and then put RTV silicone on top so the ground stays rust free. I also ran some 8 gauge to the tranny from the body. heres some pics my ground is pretty much buried under my intake setup for now.
    here you can see where the factory negative now goes to.
    another topview pic of how my wires are ran to.
    and somewhere in the mess of stuff is the tranny wire i ran
    Also I thought I'd note that the 0 gauge wire was from eBay I ordered 20 feet for 30 bucks shipped battery post was 8 bucks off of eBay as well. The rest of the misc electrical stuff was from ace hardware
  3. #83 Re: LS4 gauge install question
    Jun 2012
    awesome info!!! do you have a my ride thread or anything over on ls1tech.
    also for the air/fuel gauge glowshift does have a narrowband gauge that will match the oil pressure gauge that should work
    Tinted 7 Color Needle Air / Fuel Ratio Gauge
  4. #84 Re: LS4 gauge install question
    Arizona
    Quote Originally Posted by marines542 View Post
    Nah never got around to that on ls1 tech if you you just look at all the threads i started you should be able to track most of the **** i did. next week some time ill be going full 4' intake with a Z06 maf. BTW i looked already when i posted about the Air/fuel gauge if they had a narrowband so yea it will work perfectly with your gauge setup
  5. #85 Re: LS4 gauge install question
    Jun 2012
    Awesome man. I really appreciate all ur help. I'm gonna a jump onto ls1tech and read thru some more of ur threads. And it also sounds like the a/f gauge will be easy to install so I'm not to worried about that.
  6. #86 Re: LS4 gauge install question
    Yoga city
    yeah man i love me some ls1tech and for us the ls4 section! same username there for you guys?
  7. #87 Re: LS4 gauge install question
    Jun 2012
    Na I gots me a different user name. I never really post over there
  8. #88 Re: LS4 gauge install question
    Yoga city
    why not? i just read really and help out with electrical ?
  9. #89 Re: LS4 gauge install question
    Jun 2012
    Cause there's already so much info so I just read...learn more that way. And ask questions over here
  10. #90 Re: LS4 gauge install question
    Jun 2012
    Air/Fuel Gauge Pigtail
    found this while ordering my pcm tray
    and im also updating the original post right now with what gauges i settled on and how to install
  11. #91 Re: LS4 gauge install question
    Jun 2012
    bada bam...updated
  12. #92 Re: LS4 gauge install question
    Arizona
    You ordering a pcm tray but you don't have a intake yet? If you want I'll be selling my one pictured in my profile soon with pcm tray
  13. #93 Re: LS4 gauge install question
    Jun 2012
    is that one custom made?
  14. #94 Re: LS4 gauge install question
    Arizona
    No its a msp unit
  15. #95 Re: LS4 gauge install question
    Jun 2012
    How much would u want for it? I already got an intake I made but I like the looks of that and the box and all
  1. help me install my boost gauge!
    By des19 in forum General Tech Discussion
    Last Post: 08-22-2012, 06:01 AM
  2. Oil pressure gauge install help please
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2011, 07:54 PM
  3. Gauge install help...a-pod
    By blortz in forum Audio, Security & Visual Electronics
    Last Post: 07-31-2011, 11:26 AM
  4. Gauge pillar install
    By jdmgtp in forum General Tech Discussion
    Last Post: 06-17-2010, 06:17 AM
  5. AFR gauge install
    By amwhitey in forum General Tech Discussion
    Last Post: 02-03-2010, 01:25 PM
