Really stumped on this one. I've checked the plug & it checked out fine. As does all the wiring. What could be causing this?
Have you replaced the plug, coil, plug wire? Or just "looked" at them?
I'm saying I've had plugs and wires that looked fine but are bad...swap the coil and injector and see if the missfire follows...
move one part at a time to know which one is failing, I'd try the injector last. Also if your using your aeroforce as the scanner, check with an actual scanner as I have had one lie, saying cyl 1 missfire only to find out it was #2 cyl. Try plug, wire, coil etc. and see if the miss follows the part you've swapped out.
GL
Is it C.O.P.? Move the injector to one cyl and the coil to another and see if it moves.
coil over plug
Swap the coil. My bet is the coil is shot.
Trans temp shouldn't matter even if it's misfiring. Try moving the injector next? DOD messed up maybe?
