Thread: *PICS* Oil Catch Can Install
Results 1 to 19 of 19
  1. #1 *PICS* Oil Catch Can Install
    Arizona
    Ive had these installed for a while now however i think it should be important for any LS4 owner to put one on.after two months it trapped almost a 1/3 cup of oil. not bad for a el cheapo catch can from ebay.
    link for the catch can http://www.ebay.com/itm/UNIVERSAL-HI...40bb05&vxp=mtr
    install is simple i used 3/8' fuel line i had lying around to connect to nipple on valve cover and the same for the nipple on the intake manifold
    Install wherever you want in the engine bay however i try to keep mine away from exhaust componets or other high heat componets.
    update*** did follow up video click the link.... install pics are below
    http://s173.beta.photobucket.com/use...4_281.mp4.html
    Pics are self explanatory. and if you need the refrence the fitting on left of the can is for "dirty" air and centered fitting is for clean air. drain plug is on bottom.
    Installed pics
  2. #2 Re: oil catch can install
    Arizona
    ***updated with video
  3. #3 Re: oil catch can install
    I live here. DirtDog's Avatar
    Jun 2012
    theres the write up from ls1tech i was trying to find again for people to see. i ended up putting stainless steel scrubber inside of mine and ran a clear small tube from the inlet line to about half way down. another member recommended i do that.
    http://www.grandprixforums.net/oil-c...n-2-73407.html
    But this install guide you put over on ls1tech was the main one i used for installing this thing
  4. #4 Re: oil catch can install
    Arizona
    didnt realize someone else did this too. yea i took mine apart but decided against the tube because regardless oil is heavier than air and looking through my clean air section there is no oil i can see or smell. After the catch can and DOD disabled i barley lose oil besides whats in the catch can.
    Jun 2012
    Yea there was one piece that came with the catch can that I couldn't figure out what it was for so I didn't even use it. And im glad u put this thread over here after I talked to u on ls1tech. Those are the same pics u sent me when I was there and helped a lot with the install. I got finished pics of where I mounted mine in my ride thread.
    Sent from my DROID RAZR using Tapatalk 2
  6. #6 Re: oil catch can install
    Arizona
    i just got done relocating mine i had it lockwired to the abs module...very ****ty IMO so i relocated it and i have a new CAI on the way ill update with some engine bay pics soon glad i could be a help. didnt realize that was u on ls1tech lol
    Jun 2012
    Yup its me...I just got rid of the moto user name...I was a motard when I created this account
  8. #8 Re: oil catch can install
    Arizona
    Bumping this thread for noob awarness month
  9. #9 Re: oil catch can install
    Jun 2012
    Monkey wanna stickey in 5.3 section?
  10. #10 Re: oil catch can install
    May 2013
    Suffolk Va
    so sitting here reading this, I see where one hose goes where is the other one run to? I would run out and look but I am working......
  11. #11 Re: oil catch can install
    Jun 2012
    It runs to the rear valve cover area I can't remember exactly
  12. #12 Re: *PICS* Oil Catch Can Install
    TTT gonna do this when get yanked for cam install.
    Guessing other that goes to the rear VC area hooks into the factory line that you remove from the top of the manifold?
  13. #13 Re: *PICS* Oil Catch Can Install
    Enfield, CT
    hmmm a 2 year old thread revived?
  14. #14 Re: *PICS* Oil Catch Can Install
    Just for fun.
    It's already stickied.
  15. #15 Re: *PICS* Oil Catch Can Install
    Jun 2012
    Give me a bit and I'll post my catch can info on here to. BTW I need to finish my safely nodding thread
  16. #16 Re: *PICS* Oil Catch Can Install
    Yeah you do, slacker mcgee.
  17. #17 Re: *PICS* Oil Catch Can Install
    Jun 2012
    Quote Originally Posted by blueguy View Post
    Man I haven't been on here lately. Don't judge me
  18. #18 Re: *PICS* Oil Catch Can Install
    I never judge
  19. #19 Re: *PICS* Oil Catch Can Install
    So Cal
    Do you need to run 2 of these catch cans like the pic above? Thanks
  1. HID install pics?
    By pghtattooer in forum General Tech Discussion
    Last Post: 09-20-2010, 07:07 AM
  2. ZZP FMHE install and pics?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 02:59 AM
  3. Intercooler install pics & help?
    By qball98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:06 AM
  4. Finished Gen V Install Pics
    By Street Wolf in forum General Tech Discussion
    Last Post: 07-20-2008, 07:33 PM
  5. 'Partial' Gen V Install Pics
    Last Post: 07-14-2008, 10:47 PM
