Thread: Tool used to remove serpentine belt
Results 1 to 20 of 20
  1. #1 Tool used to remove serpentine belt
    I live here. DirtDog's Avatar
    Jun 2012
    Does anyone know what the tool is called or the part number for the removal tool for the ls4's are? I've been searching for several days and have found pics and diagrams of if but no name or where one is sold
    Sent from my DROID RAZR using Tapatalk 2
  2. #2 Re: Tool used to remove serpentine belt
    Jun 2012
  3. #3 Re: Tool used to remove serpentine belt
    Jun 2012
    after further review instead of purchasing this i will just pay the dealership a few bucks to through my new belt on...now worth to but a 130 tool that i will use once in a blue moon
  4. #4 Re: Tool used to remove serpentine belt
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    ...or use this one from Harbor Freight. I've always used a breaker bar, but if there's no room to get one on there, this tool is a lot less expensive for occassional use.
  5. #5 Re: Tool used to remove serpentine belt
    Jun 2012
    on the harbor freight one is the ends the same? like the part that connects to the pulley
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    I have this in my arsenal of tools. Don't know what I'd do without it. Makes life easier in tight spaces.
    http://www.tooldesk.com/automotive/L...Belt-Tool.aspx
    Sent using Tapatalk 2 from my GS3.
  7. #7 Re: Tool used to remove serpentine belt
    Dec 2008
    ****'s Creek
    From the Harbor Freight Website:
    This tool pays for itself ten times over the first time you use it to replace your serpentine belt. The serpentine belt tool kit works on idler pulleys requiring 15mm or 18mm hex as well as 3/8" or 1/2" square drives. Also includes 13mm, 14mm and 15mm crowfoot wrenches.
    Releases tension on serpentine belts with spring-loaded idler pulleys
    Works on idler pulleys requiring 15mm or 18mm hex, 3/8" or 1/2" square drives
    Long flat bar dimensions: 23-1/8" L x 15/16" W x 5/8" T
    Short flat bar dimensions: 9" L x 15/16" W x 3/4" T
    Shipping Weight: 2.60 lbs.
    Sale: $16.99
  8. #8 Re: Tool used to remove serpentine belt
    Jun 2012
    thanks for all the input. now i just have to check and see if this will work with my car and if i will have room to get my hands in there to work the new belt into place. its a super tight fit. im pretty sure that tool will fit over the tensioner or what ever the ls4 has to release pressure off of the belt
  9. #9 Re: Tool used to remove serpentine belt
    Arizona
    Don't waste your time remember our tensioner is to the left of our balancer one member on gmls4 used two 3or 4 inch hose clamps around it to get it off
    Jun 2012
    Quote Originally Posted by 91parkave View Post
    What exactly u saying...don't attempt it? I mean if a mechanic just uses that tool then it can't be to to hard. And I know where the tensioner is I've already investigated it
  11. #11 Re: Tool used to remove serpentine belt
    Arizona
    No I'm saying its an easy job u can do yourself I just recommended a cheaper method.
  12. #12 Re: Tool used to remove serpentine belt
    Jun 2012
    that pic is to small to actually see what its doing...do you have a bigger size
  13. #13 Re: Tool used to remove serpentine belt
    socket wrench with a short small pipe has been working for me so far.
  14. #14 Re: Tool used to remove serpentine belt
    Jun 2012
    hey 91parkave im gonna have to try the hose clap options. i bought one of the tools they listed above to use on it today and i would like to announce proudly that none of them will work. After further investigation i figured out why tool gm designed for use with the belt is the way it is. so without that stupid expensive special tool you have to get creative
  15. #15 Re: Tool used to remove serpentine belt
    Arizona
    Sorry to hear that but see if this helps u get a visual since u already bought the tool Special GM tool to change serp belt ?
  16. #16 Re: Tool used to remove serpentine belt
    Jun 2012
    Yea Ive got that page book marked. But u can't use just any serpentine tool cause the pulley next to it gets in the way. So I guess I'll take passenger side tire off and work thru the wheel well at it. How did that other person use clamps on it?
  17. #17 Re: Tool used to remove serpentine belt
    Arizona
    clamps around the spring then tighten it as much as it takes to be able to get the belt off
  18. #18 Re: Tool used to remove serpentine belt
    Jun 2012
    O OK that makes sense. I have a ton of screw down clamps from jobs on cars so I'll just do it that way. Seems cheaper to...free. That pic u posted was to small for me to see.
  19. #19 Re: Tool used to remove serpentine belt
    Arizona
    that pic was on gmls4 too cant remeber where
  20. #20 Re: Tool used to remove serpentine belt
    Jun 2012
    O OK. Well when I get back from Cali I will take pics and post of that method for fellow gxp owners
  1. Serpentine belt
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2012, 08:42 PM
  2. serpentine belt
    By fremmy182 in forum General Tech Discussion
    Last Post: 10-22-2010, 05:04 PM
  3. serpentine belt
    By rmil03 in forum General Tech Discussion
    Last Post: 09-01-2010, 05:44 PM
  4. serpentine belt
    By Getagrip in forum General Tech Discussion
    Last Post: 04-21-2010, 05:26 PM
  5. serpentine belt
    By keenan00gtp in forum General Tech Discussion
    Last Post: 01-25-2009, 11:43 AM
