Thread: Transmission Replacement.......
Results 1 to 7 of 7
  1. #1 Transmission Replacement.......
    Apr 2011
    Maryland
    Ok so I just found out that I need A transmission for my 2008 Grand Prix GXP 5.3..... Have anyone replaced theirs and how much do it cost??? And where sould I go to have it replaced besides the DEALER??? HELP PLEASE!!!!!!!!!!!!
  2. #2 Re: Transmission Replacement.......
    You dont got a 5y/100,000m warranty?
    A transmission shop???
    To get it rebuilt.
    Or
    Use car-part to find a trans that will fit your car and swap it in.
  3. #3 Re: Transmission Replacement.......
    Apr 2011
    Maryland
    Sorry Bro, I just hit my 100,00 mark. I talk 2 a guy at a local junk yard n he said that he has a Trans for my car that came out of a 2008 LS-4 with 12K and he wants $800 for it. What do you guys think?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Seems fair I'm not sure what these go for but it's a newer moddle
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  5. #5 Re: Transmission Replacement.......
    Oklahoma City
    That's not bad at all. It's easy to change, just rent or borrow an engine hoist and drop that mother out. Good time to change any front suspension components as well.
    ZZP S2IC-XP-CC105/ls1 retainers-PPSC-N*-85MM MAFF-HAI K&N-180Therm-AL103-8RIB PULLEYS-SFI 5%OD BALLANCER-DOUBEL ROLLER-CCPUSH RODS-ZZP 3KSTALL-15/16 3:29-ZZP IS- TOGS-3"BORLA EXHAUST-ELIMASLIP-42.5 LUCAS-ZZP LOGS
  6. #6 Re: Transmission Replacement.......
    Oct 2012
    Winfield, IL
    Quote Originally Posted by tonio301 View Post
    Do you get to visually verify the donor car and the mileage that this transmission is coming out of? Seeing is believing....and if I were you I would not be believing the mileage until I've seen the donor car with the trans in it. If it can't be verified, you'd be better off spending your money having your own transmission rebuilt with durable parts at a reputable shop. At least then you would know exactly what you have.
  7. #7 Re: Transmission Replacement.......
    I wouldnt touch a trans out of an LS4 car.
    Don't care how many "miles" are on it.
    Welp: you have an LS4 car. Goodluck.
    Your best bet is a built transmission and an external cooler. see: www.tripleedgeperformance.com
    Junk yard transmissions will fail just like your current one did.
  1. icm replacement
    By ericg1181 in forum General Tech Discussion
    Last Post: 07-13-2012, 08:38 PM
  2. Oil Pan Replacement??
    By madman1701 in forum General Tech Discussion
    Last Post: 10-03-2011, 01:50 PM
  3. PCV Replacement
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 03:21 PM
  4. BCM replacement
    By EricGTP in forum General Tech Discussion
    Last Post: 04-28-2010, 07:33 PM
  5. LIM replacement
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-24-2009, 04:32 PM
