Thread: P442 and P455 Engine Codes
Results 1 to 6 of 6
  1. #1 P442 and P455 Engine Codes
    Jul 2012
    Syracuse
    I tried searching for these codes, but I cannot seem to find much on them. I have a 2008 GXP. I keep drawing these codes. I reset them and they return. I have tried replacing the gas cap as I was getting an error in the DIC to check the gas cap. That did not help. Any suggestions on beginning to diagnose the root cause for the codes? As always, I appreciate anyone's input.
  2. #2 Re: P442 and P455 Engine Codes
    I can't look into it much at the moment. But try googling "GM DTC P04XX" with the XX being the last two digits of your codes. I found a lot of info. Work...holds me back though.
  3. #3 Re: P442 and P455 Engine Codes
    They are EVAP codes ...I'd check the EVAP purge solenoid if you haven't...or the vac lines running to it. They are a common failure on plenty of GM cars...had the issue on my silver GT and my old Cobalt as well.
    Secondly, did you replace the gas cap with an OEM one or an aftermarket one? Because I've ran into the aftermarket ones being pretty much junk...for reference, my Cobalt EVAP solenoid was like $40...not sure on the GXP.
  4. #4 Re: P442 and P455 Engine Codes
    Jul 2012
    Syracuse
    I will search and see what comes up.
    I did replace with a GM OEM gas cap. I was hoping that would be the issue, but alais is was not.
  5. #5 Re: P442 and P455 Engine Codes
    SE Level Member Hoss Lanier's Avatar
    Apr 2011
    Calhoun, La.
    DTC P0442: Evaporative Emission (EVAP) System Small Leak Detected
    DTC P0455: Evaporative Emission (EVAP) System Large Leak
    trouble tree is kind of large for the P0455
  6. #6 Re: P442 and P455 Engine Codes
    Can you post just the diagnostic aids? That's where I find the fix 95% of the time.
  1. How to find out engine codes?
    By tcman49 in forum General Grand Prix Discussion
    Last Post: 01-03-2012, 04:14 PM
  2. Have 2 engine codes
    By GAFF in forum General Tech Discussion
    Last Post: 02-15-2011, 03:35 PM
  3. Engine codes
    By postalizer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2010, 10:20 AM
  4. Help with SES codes, engine surging.
    By Fast68Camaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 06:20 AM
  5. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
