anyone put the 5.3 throttle body spacer on yalls GP?
i need pros and cons lol
also does anyone know how i can get a hold of a replacement filter for the cold air inductions intake kit like the one off of PFYC?
is there a throttle body upgrade?
Can you out flow it??
I highly doubt it, unless your running a stupid high HP turbo setup.
Ebay has nice AEM filters, otherwise any high flow, non oiled filter will suffice.
Spacers are like "snake-oil" won't help in the least bit.
Dry filters are preferred since the MAF can easily get coated in oil and cause stuttering/other oddball issues.
Everyone who says oiled filters can cause MAF problems are just being parrots. I have used oiled filters for over 12 years now and have NEVER had a MAF issue.
User error. You are overoiling your filter. I have NEVER NEVER NEVER had oil issues with my MAF.
Oil filters dont filter as well as paper.
Is that reason enough not to use them?
Its the other way around. You are only going to see people post who have problems. People aren't going to post when they don't have problems.
I belong to other forums and there are probably 10,000 members with oil base filters and maybe 2 or 3 have had problems. Its not a common issue. Its only an issue if the filter is over oiled.
