Thread: Car does a knock or a creak noise whenever you turn
Results 1 to 11 of 11
  1. #1 Car does a knock or a creak noise whenever you turn
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    For the past few months my dads gxp at low speeds(parking lots n stuff,) whenever you turn the wheel or accelerate at low speeds or hit a bump while driving the car makes a knock or creak noise. You can feel it in the wheel and the gas pedal too. Anyone know or heard of this? thanks
    (sold) 1998 GP GT- ssm90'd. ported blower and lim, zzp fuel logs, l67 inj, 103's, zzp 2.5"dp, magnaflow mufflers, zzp plog, 3.8" ssm90 pulley, eibach springs, short db's
    2002 Z28 LS1- stock for now
    2012 chevy sonic 5spd
  2. #2 Re: Car does a knock or a creak noise whenever you turn
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    sounds like a CV joint or axle? I know nothing about cars but I do that all my hondas did that and it was always the same thing, not a real expensive fix I would guess less than $200
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  3. #3 Re: Car does a knock or a creak noise whenever you turn
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    I had the SAME exact problem. Turned out it was the struts. Spotted me $500. That hurt the wallet. It's not a HUGE problem but I would get it fixed.
    -ljmonnin12
  4. #4 Re: Car does a knock or a creak noise whenever you turn
    Oh really the front struts? Okay thanks il let my dad know
  5. #5 Re: Car does a knock or a creak noise whenever you turn
    Nov 2010
    Sidney, OH
    Yep. Front ones. And i'm pretty sure my mechanic replaced one of the front strut mounts too.
    -ljmonnin12
  6. #6 Re: Car does a knock or a creak noise whenever you turn
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Dont know if you have herd of the ISS.. intermidate steering shaft.... they will do the same thing a low speeds. it connects the steering wheel to power steering rack. Sometimes they just need lubed. GM has a special kit for it or others have use White Litium greese in the spray can
  7. #7 Re: Car does a knock or a creak noise whenever you turn
    SE Level Member Pontiacfanatic's Avatar
    Apr 2011
    SC Oklahoma
    My 07 GXP does the same thing, but only everyo once in a while. Ill hold my 500$ for as long as i can :/
  8. #8 Re: Car does a knock or a creak noise whenever you turn
    Sep 2011
    Hays, Ks
    Is there any good aftermarket strut options out there. Bilstien, koni, ect. or is it best to stick with OE?
  9. #9 Re: Car does a knock or a creak noise whenever you turn
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    mine did the same thing until i took sway bay bushings off and greased them...noise gone
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  10. #10 Re: Car does a knock or a creak noise whenever you turn
    Quote Originally Posted by Rubberducky700 View Post
    bilsteins are out there.
    most gawk at the price tag and jump for KYB GR-2's
  11. #11 Re: Car does a knock or a creak noise whenever you turn
    Sep 2011
    Hays, Ks
    sounds good, Don't really need them at this point in time but was curious.
    Quote Originally Posted by djrepoman View Post
    Never thought of that but seams like a good attempt to save some money, especially if the struts are still good. I wonder if Lithium grease would do the same thing with out removing the sway bar.
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  3. L36 engine noise.. rod knock?
    By gpgt98 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2011, 08:58 AM
  4. grinding noise on turn
    By wade722 in forum Brakes/Suspension/Chassis
    Last Post: 08-26-2010, 06:15 PM
  5. Noise when i accellerate and turn corners.
    By packerfanjc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2009, 01:13 AM
