Thread: LS6 swap what would need to be done???
Results 1 to 20 of 31
  1. #1 LS6 swap what would need to be done???
    Baltimore
    i was day dreaming the other day about swapping the ls4 for a ls6, so i went on line and found that there is a company in PA that swaps the pontiac solstice engines with the ls6. Now i know what your saying in your head "the solstice is a RWD" but lets dream for sec here let me here what you guys think.
  2. #2 Re: LS6 swap what would need to be done???
    GT Level Member Hawkins04's Avatar
    Ga
    why?
    Wouldn't You Like To Know
  3. #3 Re: LS6 swap what would need to be done???
    you cant.
    crankshaft is TOO LONG.
    the LS4 BARELY fits in the GP and only because they shortened the crankshaft.
  4. #4 Re: LS6 swap what would need to be done???
    Baltimore
    Quote Originally Posted by Hawkins04 View Post
    why?
    just for convo.
  5. #5 Re: LS6 swap what would need to be done???
    GTP Level Member
    Pittsburgh
    you can install the LS6 upper intake, the LSx Series motors are pretty close to being the same as is.
    2003 SSEi,
  6. #6 Re: LS6 swap what would need to be done???
    Ga
    yea the intake will need to be modded to fit though
  7. #7 Re: LS6 swap what would need to be done???
    Baltimore
    i've been wondering what are the HP gains and what kind of tuneing need to be done.
  8. #8 Re: LS6 swap what would need to be done???
    Ga
    not sure about tuning but if you dont have anyother mods its worthlesss only real gains if you go cam
  9. #9 Re: LS6 swap what would need to be done???
    Baltimore
    so lets say you have a CAI you see modest gain then?
  10. #10 Re: LS6 swap what would need to be done???
    Ga
    a few hp thats about it and you will need a tb adapter if you do the ls6/ls1 swap. its not worth all the work and fab for the little hp gain if you dont have any serious mods
  11. #11 Re: LS6 swap what would need to be done???
    Apr 2009
    stockton ca
    Money time trial and error and a shiz load of fabrication work plus cost of trans and engine
  12. #12 Re: LS6 swap what would need to be done???
    Ga
    Quote Originally Posted by TorqueAutoMotiv View Post
    what is the cost of the motor and trans you are talking about?
  13. #13 Re: LS6 swap what would need to be done???
    You'd need to convert the car to RWD or make it wider.
    Both would cost 20 grand or more.
  14. #14 Re: LS6 swap what would need to be done???
    Baltimore
    that would be freakin awesome
  15. #15 Re: LS6 swap what would need to be done???
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    The LS4 has the shorten crank with only one belt. Also the Starter is mounted to the trans not the motor like other LSX. Seems to me the bolt patern for the bell housing is different. you could do the LS6 intake though.
  16. #16 Re: LS6 swap what would need to be done???
    http://www.grandprixforums.net/sick-...-ss-35574.html
    Heres the answer....
    Custom dart block LOL have fun.
  17. #17 Re: LS6 swap what would need to be done???
    Baltimore
    dude that is awesome.
  18. #18 Re: LS6 swap what would need to be done???
    Ga
    just stay with the LS4 there should be another turbo kit coming out in a few weeks. they are waiting to get it dyno'd now
  19. #19 Re: LS6 swap what would need to be done???
    Apr 2009
    stockton ca
    I still say sts rear mount set up on a gxp would be sick
  20. #20 Re: LS6 swap what would need to be done???
    Ga
    there is a guy that has a rear mount setup and really likes it
  1. i might top swap
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 12:15 AM
  2. Top Swap
    By MetalMan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2010, 10:49 PM
  3. Top Swap
    By MetalMan in forum General Tech Discussion
    Last Post: 04-30-2010, 07:51 AM
  4. Top swap help
    By uNda6gT in forum Northeast
    Last Post: 03-12-2010, 12:41 AM
  5. l36 to l67 swap
    By sportred04 in forum General Tech Discussion
    Last Post: 03-08-2010, 02:48 PM
