Thread: Sprayed GXP
Results 1 to 20 of 24
  1. #1 Sprayed GXP
    SE Level Member Dcf250's Avatar
    Nov 2009
    Vacaville CA
    Has anyone sprayed their GXP. Obivously our cars dont need the extra power down low, but freeway pulls with spray are fantastic. Anybody know what our engines can take safely? I know the LS family loves nitrous, so i can only expect our engines to be the same. Thx all.
    06 GXP: Exhaust, intake
  2. #2 Re: Sprayed GXP
    I bet that thing would take a 100 shot all day long.
  3. #3 Re: Sprayed GXP
    id agree with nick. the motor will probably take a 100 shot easily.
  4. #4 Re: Sprayed GXP
    Nov 2009
    Vacaville CA
    thats about what i thought, do u think something like a cortex would push enough extra fuel into the motoe. if not, any ideas?
  5. #5 Re: Sprayed GXP
    Just buy a controlled ZEX kit.
    /end
  6. #6 Re: Sprayed GXP
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    what are the penalties of getting caught with spray? im pretty sure its horrible here in GA and is considered hazmat or something
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  7. #7 Re: Sprayed GXP
    Jan 2009
    Farmington Hills, MI
    Dunno about penalties, but I'm sure there is a way to legally use N20 even if it involves removing the bottle when on the street or something. Several guys have safely run 100HP wet shots in these cars. Rossko85 used to post on here, and he runs the N20 with a rear mount turbo now.
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  8. #8 Re: Sprayed GXP
    South
    i could only dream of performance like that. i got the money for nos but not for turbo
  9. #9 Re: Sprayed GXP
    I live here. UR LOSN's Avatar
    Rockford, IL
    ANY LS based motor CAN take 150wet shot everyday of the week for years.
    I sprayed my truck 300 2 years ago. never had any problems, and plugs/pistons looked brand new when I pulled the heads for better ones.
  10. #10 Re: Sprayed GXP
    South
    ive just always heard that nos was so bad for motors, my uncle had a 75 shot on his rsx and it didnt seem to hurt it...he had the zex kit that opens and closes at certain rpm's
  11. #11 Re: Sprayed GXP
    GT Level Member sic6's Avatar
    san marcos, tx
    Just make sure to pull some timing out when you do spray.
  12. #12 Re: Sprayed GXP
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    honda 4 cyls are a little bit different of a story when it comes to nos the ls4 will like it WAY moar
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  13. #13 Re: Sprayed GXP
    Nov 2009
    Boston
    would love to do that setup on my GXP..actually could someone point me in the right direction for our cars? What price are we talking about?
  14. #14 Re: Sprayed GXP
    GT Level Member jdmgtp's Avatar
    MI
    Quote Originally Posted by UR LOSN View Post
    QFT, properly setup it can take even more.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  15. #15 Re: Sprayed GXP
    Nov 2009
    Boston
    Quote Originally Posted by jdmgtp View Post
    That I do not beleive. Thats a lot of HP going through a stock engine..
  16. #16 Re: Sprayed GXP
    MI
    Quote Originally Posted by Specter GXP View Post
    I was talking about the 150 shot.
  17. #17 Re: Sprayed GXP
    Nov 2009
    Boston
    ohh ok.
    so what is the pricerange to do this? What would a ballpark figure be?
  18. #18 Re: Sprayed GXP
    Whatever a Nitrous kit runs? $500 bucks plus filling the bottle?
  19. #19 Re: Sprayed GXP
    MI
    yeah that about right, or you can get a used kit for cheaper. Also, here's a little clip of a post I made over at LS1tech.
    that looks like a decent kit. I ran a zex wet kit on my vette with good results. Here's a list of HIGHLY recommended things you should get:
    window switch
    bottle warmer (pressure controlled not temperature)
    fuel and nitrous filters (if the kit doesn't come with them)
    fuel pressure safety switch
    remote bottle opener (not a must but recommended)
    tune
    NGK TR6's gapped at .040"
    I have quit a bit of experience with nitrous, if you have anymore questions don't hesitate to ask.
  20. #20 Re: Sprayed GXP
    SE Level Member 707chance's Avatar
    Fredericksburg Va
    I have a N2O system set up in my GXP. Rossko IS THE MAN when it comes to N2O and our cars. I can send you his PMs explaining his philosophy and setup if you want. Following his advice I went with a wet system with all the safety features.
    2006 GXP almost done! I/H/C/E, TEPw/3.29s, small shot
