Thread: GXP meaning
Results 21 to 40 of 59
  1. #21 Re: GXP meaning
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Stock for stock a GXP is faster. just with like 300 dollar worth of bolt ons then it becomes a drivers race.
  2. #22 Re: GXP meaning
    Denver
    Quote Originally Posted by Injun #4 View Post
    I would have to strongly disagree with that statement. Lets look at some specs shall we.....
    97-03 GTP
    Horsepower: 240 hp
    Torque: 280 ft-lbs
    Max Horsepower: 5200 rpm
    Max Torque: 3600 rpm
    Curb Weight: 3559 lbs
    04-05 GTP/06-07 GT
    Horsepower: 260 hp
    Torque: 280 ft-lbs
    Max Horsepower: 5600 rpm
    Curb Weight: 3583 lbs
    05-08 GXP
    Horsepower: 303 hp
    Torque: 323 ft-lbs
    Max Torque: 4400 rpm
    Curb Weight: 3600 lbs
    GXP is only 40 pounds heavier, and has 40+ hp and 40+ ft-lbs tq over the GTP/GT, giving it a better hp/tq to weight ratio. A decently modded supercharged 3.8 will walk a 5.3; but stock vs stock, 5.3 will win all day long.
    Like I said I got a 02 Modded GTP and I got a Damn Near Stock 06 Gxp and the GXP put's up Better Times with the same Driver.... And we all know GM Always down grades Specs on horsepower, Dynoed mine after I baby'd to to the 1500 mark and the GXP dynoed at 320, after my Intake, Exaust, Mass Airflow Sensor, and SuperChips Flash Paq im at the 500 mark, Might i add all under 2k
    See I can play nice
  3. #23 Re: GXP meaning
    Denver
    Quote Originally Posted by Swash View Post
    I wanted to be a Marine
    -Swash
    And I wanted a G8
    But like all Pontiac Lovers/owners I guess I'll have to wait for a used One Oh well thank god nothing holds it's Value anymore
  4. #24 Re: GXP meaning
    Quote Originally Posted by SJR GXP View Post
    No Bolt-ons GXP is putting down anywhere near 500 CRANK hp, let alone 400. This isn't bashing it is a fact. Dyno sheet please? The Turbocharged GXP put down numbers around 480-500 WHEEL Horsepower. I'm just curious to know how you got almost 200 horsepower from a intake/exhaust/tune.
  5. #25 Re: GXP meaning
    Denver
    I know you like all People That can't do Math or the Research for your self let me break it down and might i add i am tryin to play nice
    Base Hp Before Mods 320
    + 35HP With Intake
    +10HP with Mass Air Flow Sensor __P.s you need all of this for the Superchips Flash Paq to work Correctly for Max Power
    +20 Magnaflow
    Humm we are at 385 Already Then You Need to Run 93 Octain or higher,
    Then while your flash Paq is in custom tuning Mode__(Classified)___(read the book it came with)
    +90hp That easy at 475 in the front wheels.
  6. #26 Re: GXP meaning
    Barksdale AFB, LA
    + 35HP With Intake
    +20 Magnaflow
    It's great that you made this statement since now we know you're talking out your ass. He can't do the math since you're using ricer math and adding up the magical HP numbers on products.
    The 5.3L is not under rated from the factory. It has 303HP at the CRANK stock. This is verified by tons of the 2006+ Impala SS owners at NAIOA who have had their car dyno'd and get about 245-250HP at the wheels. This is the stock base line. FYI, there is no way to dyno your car at the crank (like you're claiming with the numbers you're quoting) without pulling the engine. No one who knows anything about cars refers to the crank HP. All that matters is what is going to the wheels.
    You do not get those kinds of gains from tunes, catbacks, and from silly sensors. Produce a dyno sheet and disappoint yourself. A modded out 5.3L with ported/polished heads, cam, exhaust upgrades, and a good tune put down 278HP at the WHEELS (which is an estimated 346.25 crank HP). You can see the dyno yourself here:
    North American Impala Owners Association - Garage - mixerda's 2007 Chevrolet Impala
    Just click on the icon next to his run in the "dyno run" table.
    So either put up or shut up.
    2009 Subaru Impreza WRX STI
  7. #27 Re: GXP meaning
    Becca Boo MizzBecca's Avatar
    Michigan
    I drive a POS
  8. #28 Re: GXP meaning
    GT Level Member Injun #4's Avatar
    Anderson, SC
    Quote Originally Posted by Sabrewings View Post
    Exactly. If he got those gains with those mods, I want part numbers of everything that was installed and parameters for the tune.
    This one has a V8.
    Why not just make a V6 faster?
    This one has a V8.
  9. #29 Re: GXP meaning
    Wichita
    Kinda like getting a smaller s/c pulley. You can gain a certain amount of HP w/ the needed supporting mods. If only our cars got the claimed horsepower from each bolt-on we added. Think mine'd be around 320. Heh don't we all wish = D
  10. #30 Re: GXP meaning
    + 35HP With Intake
    +20 Magnaflow
    O
    M
    F
    G
    BWHAHAHAHAHAHAHAHA!!! You are so lucky I was drinking something when I read that or I would have ruined my monitor. You are such a noob on SO many levels and you don't even know it, do you?
    LOL
    It also goes to show you that you know nothing about the GXP so let me tell you this little bit like Sabre pointed out. 303hp stock. That is to the crank. You have a 20%-ish loss through the drivetrain to make the power, so you go back and do the math anyway, since I am playing nice too and giving you a LITTLE chance to redeem yourself. And use real figures too, because the only intake system I have ever heard of that added 35 horsepower was on a Shelby GT500...and that was yet again TO THE CRANK. Even K&N proves you wrong. Here is their dyno for a 5.3 Liter V8 stock and then with the new K&N Intake installed. You = Eating your words right now.
    http://www.knfilters.com/dynocharts/63-3059_dyno.pdf
    I'd bet with a intake/exhaust/MAF/tune...you might put down 275 or so to the wheels. Get a life and stop talking out of your ass, I hope you get banned just for the sheer amount of IQ points I lost reading your post.
    Reading that, I suppose that other modded GTP of yours probably has a 3.0" pulley and a straight pipe which added like 19psi and 75 right rear wheel horsepower. Am I right? If not please tell me the mods and how much power they REALLY added.
    And with that...Thanks you guys (Sabre and Injun)...it just goes to show what kind of a person we are dealing with here. Oh, and I am saving his post too...saving it just for something to laugh at.
  11. #31 Re: GXP meaning
    Michigan
    O
    M
    F
    G
    LOL
    God damnit, I was drinking something when I read yours, def ruined a work keyboard.
    I drive a POS
  12. #32 Re: GXP meaning
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    sue the tow truck company for your rim. get quote from dealer for new rim as u cant lose that one reagrdless if he warned u about possible damage beforehand or not. its negligence
  13. #33 Re: GXP meaning
    Wichita
    Apparently the G-Series part is referring to the G5, G6, & G8. Not the Grand Prix? This article explains:
    Pontiac G Series - Pontiac Review - Car Review Articles
  14. #34 Re: GXP meaning
    Dec 2008
    colorado
    Ya sorry but my Stock GXP only put down 245 hp. which is correct for a 20% drivtrain loss
  15. #35 Re: GXP meaning
    Quote Originally Posted by Panther427 View Post
    See...owned by another GXP member AND he lives in Colorado
  16. #36 Re: GXP meaning
    Anderson, SC
    Mine put down 252 whp stock.....installed K&N and got it up to 263 whp (259 whp in high heat and humidity).
    This one has a V8.
    This one has a V8.
  17. #37 Re: GXP meaning
    East Coast Air and High Altitude in Colorado might have something to do with that
  18. #38 Re: GXP meaning
    Anderson, SC
    Yep....air's pretty thin up there in Colorado. Air's even thinner where SJR GXP is......thin enough to cause hallucinations.
    This one has a V8.
    This one has a V8.
  19. #39 Re: GXP meaning
    I don't even think a complete LACK of oxygen would make anyone think that crazy
  20. #40 Re: GXP meaning
    SE Level Member bladerunner's Avatar
    Feb 2009
    AZ
    sjr gxp i sent you a pm askin how you like the superchips, what do you think of it? how is the trans support tune on it?? I REALLY dont see how its possible to get 90 hp from a tune when superchips sales managers tell me from the books about 18-20 hp WITH a 91 octane tune. again im not makin fun just lookin for any info from a non-salesman trying to get me to buy a product...
    2006 GXP, stock for now
