Thread: Won't turn over , new batt. Help
Results 1 to 15 of 15
  1. #1 Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Hello I have a 05 gxp that won't turn over , changed battery, tested starter, it doesn't even click , now if I hook charger straight to starter it'll turn over but won't spin like it should.(acts like batt. low) turns over slow then quits... any ideas?? I've checked battery connections , any ideas?? Also checked grounds but plan on adding some today just to be sure... if charger is hooked to starter why wouldn't it turn over fast like it should??? Any help is greatly appreciated...
    Thanks
    Jerad
  2. #2 Re: Won't turn over , new batt. Help
    St. Louis
    Not sure hooking the charger to the starter is a good idea, but never tried it. If it won't spin over fast enough to start then I would suspect the starter is toast.
    Other than that have you checked all the fuses? When was the last time it started/ran on it's own? Did this just happen out of the blue?
  3. #3 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Started after battery died the other day until then it was running fine... I have had issues with the ignition before ,(when you turn key if display doesn't say gxp like normal them it wouldn't turn over but if you shut it off and tried it again when gxp came up on display then it started everytime) and I get my gxp on display now but doesn't turn over now... I'm not sure what I'm missing , I've unbelted everything in case something was locking up (h2o pump or alt., etc) but still same thing... added grounds , ohmed out grounds and power wires both seem good... I do have a couple relays making noise on pass side fender but usually shut up , and I swapped relays with similar ones in fuse box... no difference... any ideas would be greatly appreciated... I can't be the only one to run into this...
    Thanks
    Jerad
  4. #4 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Hello and it only happened about a week ago when I let the battery go dead... until then it was running fine, (now ignition switch has messed up in past, if you turn key and gxp shows on display then it started fine but if no gxp showed up on display then it wouldn't even try to turn over and you'd have to cycle key off and back on until gxp showed on display then good to go) but never took more than a couple tries... but now I get gxp on display and still doesn't try to start... it'll click like battery's dead sometimes and you can hear relays clicking on fuse box on passenger fender but still doesn't turn over... and battery's new, starters new and connections all seem good , ohm out ok... so I'm hoping someone's ran into this before... because I'm out of ideas... any help is greatly appreciated!!
    Thanks
    Jerad
  5. #5 Re: Won't turn over , new batt. Help
    St. Louis
    Do you have a second ignition key for this car? If so, try that one and see if it starts.
  6. #6 Re: Won't turn over , new batt. Help
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I wish mine said "GXP" on the display. It just says "GP"....
  7. #7 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    I will try that today when I get home , i only have two keys and only has pontiac symbol on it... any other ideas??
    Thanks
    Jerad
  8. #8 Re: Won't turn over , new batt. Help
    St. Louis
    Take a read through this thread--> 2005 gp gxp no crank - no start --- help
  9. #9 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Read thru no help, thanks but any more ideas? I've went ahead and changed ignition because I wasn't sure if that was issue bit nothings changed, even replaced the relays under hood that was clicking when trying to start.. not really sure where to go from here, it's been way to long being broken tho... admittedly I've been out with a bad knee so haven't messed with it in a while but it's time to figure it out... I can't be only one who's ran into this... any help is greatly appreciated and I will post my findings for next poor soul who has this issue once I find problem...
    Thanks to all
    Jerad
  10. #10 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Well I went thru thread and that didn't seem to be my problem but it was worth checking.. any other ideas?? I went ahead and replaced ignition but nothing changed, also changed 4 relays that was clicking in fuse box under hood... idk what it could be but wanna blame it on the remote start or whatever would keep it from turning over full speed.. cause it seems like it's dragging or being told not to start(anti theft possibly idk) any help I'd greatly appreciated....
    Thanks
    Jerad
  11. #11 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Idk what's wrong but I've responded to this post like 4 different times so ?? But I did go thru post that link sent me to but did not help.. since I've replaced ignition and the relays under hood that were clicking when trying to start... . Any other ideas would be greatly appreciated, like I said I can't be the only one who's ran into this..
    Thanks
    Jerad
  12. #12 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Idk why but I've responded to this like 3 times but I tried the link and it didn't apply (none of my fuse holders seemed loose ) but it was a possibility so any other ones that anybody knows of?? I've went ahead and changed out ignition and the relays on pass side engine compartment... I can't be the only one to run into this ?? Any and all help is appreciated!!!
    Thanks
    Jerad
  13. #13 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Idk why it keeps deleting my responses.. but I did look at link and didn't notice anything loose on mine but thanks and I'm open to any more ideas because I'm kinda stumped.. since last post(least that is posted) I've replaced relays on pass side under hood fuse box, replaced ignition switch.. any ideas??
    Thanks
    Jerad
  14. #14 Re: Won't turn over , new batt. Help
    Nov 2021
    Indiana
    Ok update , well replaced ecu with one programmed to vin and went thru key relearn procedure and after multiple tries it finally took and I'm up and running...
  15. #15 Re: Won't turn over , new batt. Help
    St. Louis
    Thank you for posting the resolution to this one. Strange the ECU decided to crap out but it's just electronics so anything is possible, lol.
  1. 2005 running lights/Amber turn signals-turn off?
    By Madness in forum General Tech Discussion
    Last Post: 09-19-2016, 10:49 AM
  2. Add Factory Navigation Radio 2008 Pontiac Grand Prix GXP Turn By Turn Disabled (TPMS)
    By jlagomarsino in forum Audio, Security & Visual Electronics
    Last Post: 04-24-2015, 07:59 AM
  3. Has anyone modified combination stop/turn/tail lights to independent turn signals?
    By April Thompson in forum Visual/Body Modifications
    Last Post: 03-02-2015, 08:22 PM
  4. Replies: 4
    Last Post: 02-20-2011, 09:46 PM
  5. power cable from batt
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 12:15 PM
