Thread: Lifter Replacement
Results 1 to 2 of 2
  1. #1 Lifter Replacement
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I've got at least one lifter going out, which (I think) is why my DoD hasn't been working. I've decided to go the "replace the stock parts and just tune it out" route because I don't want to spend more on the engine than I did to buy the car.
    The problem is, I've only got one reliable part number for the DoD lifters (12680871), and I obviously want to replace them all at the same time. Does anyone know the other GM part number I need? Thanks.
  2. #2 Re: Lifter Replacement
    May 2016
    Burns City, Indiana
    Ok if your replacing lifters you must pull heads, SOOOO your money ahead in sourcing two new lifter holders and 8 new non DOD lifters (should replace all the lifters as your into it) and new valley cover with block off seals AND buy the drive in block off plugs. And your cam probably should be three bolt, and you'll need three bolt cam gear with appropriate 1x or 4 X set up and appropriate timing chain setup. IE non spring loaded.
    And you'll need a tune. Spend extra and get ARP head bolts as they are reuseable.
  1. 2008 GXP Lifter Removal and Replacement
    By KenG in forum 5.3L V8 (LS4)
    Last Post: 10-15-2017, 07:13 PM
  2. lifter replacement
    By Eric Whitter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2012, 04:05 PM
  3. Lifter and LIM gasket replacement
    By plasmeh in forum General Tech Discussion
    Last Post: 05-09-2011, 10:11 PM
  4. Advice on lifter replacement
    By goldgp in forum General Tech Discussion
    Last Post: 02-12-2011, 08:51 PM
  5. Lifter replacement
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 05:35 PM
