I got an OBDII message telling me the oil pressure sensor was out, so I replaced it. The code came back last week, and I cleared it.
Now, apparently, the sensor is working, because I got "Low Oil Pressure" on the DIC. I checked the level, and it was low. Immediately threw in a quart.
I have never gotten a "Low Oil Level" message, which is one of the reasons I assume the DoD isn't working. Does this masterpiece not HAVE an oil level sensor, just as it can't be bothered to tell me when the DoD is active, or do I have a dead sensor somewhere? If so, approximately where?
#2
Re: Oil Pressure Issue
Revised situation--I now have TWO oil pressure sensor codes, 0521 and 0522. Has my non-OEM sensor already taken a ****, or is the problem that (despite buying picks for the specific purpose) I couldn't get the screen out to clean it or change it?
#3
03-21-2021
bet its the oil pick up tube o ring failure deal. fails where it bolts to the pump. then sucks air. id stop driving it till you figure it out.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#4
Turbo is the way to go.
03-21-2021
Non OEM sensors are usually never that good.
Fivefingerdeathpunch
ive learned that with quite a few different car makes, aftermarket sensors have a tendency to be this way.
#6
I changed out two of them aftermarket until I finally said fu** it and bought an oem. Been fine since.
#7
It was the O-ring. Thanks for the help!
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
