Thread: TB Adapters for swapped intakes
Results 1 to 6 of 6
  1. #1 TB Adapters for swapped intakes
    Wichita
    Ok, so I'm having trouble finding the right TB adapter for the LS6 intake swap. Which kinda sucks cos I already have everything else needed. I'm wondering if I can get away with using this adapter; LS Throttle Body Adapter / 3 Bolt Intake to 4 Bolt TB - Throttle Body - LS Swap Adapters - LS
    Any thoughts comments or suggestions appreciated.
  2. #2 Re: TB Adapters for swapped intakes
    I don't see why that wouldn't work.
  3. #3 Re: TB Adapters for swapped intakes
    Wichita
    I'll keep looking around but may end up getting that thing to get by for a while. I'd like to do an LS2 TB but dont wanna spare the cash for one rn.
  4. #4 Re: TB Adapters for swapped intakes
    Arizona
    That wont work with your ls4tb it's meant for ls2/3 Tbs to be adapted to a 3 bolt intake like the ls6. If you have a 08 but the ls3 gold blade they are 130 new off amazon
  5. #5 Re: TB Adapters for swapped intakes
    Wichita
    Did and done! All i need now is to find someone local to cut & weld the OPSU. Thanks!
  6. #6 Re: TB Adapters for swapped intakes
    Wichita
    Wow just realised other people still do the LS1/6 swap and larger TB's. So, for anyone doing the swap having a hard time finding those TB adapters try ICTBillet.com. they're a local place out of ICT Kansas. They sell a 4 bolt to 3 boltadapter as well as an additional spacer to make it work for larger TB's. Man, i shoulda shared this a long hot minute ago. Or in a thread of its own....
  1. Aux Adapters
    By killuminati in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2013, 10:42 PM
  2. Air intakes
    By NewGPkid in forum 04+ Specifics
    Last Post: 10-19-2010, 04:23 PM
  3. which is better on intakes?
    By a98gtp4u in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 08:43 AM
  4. Air Intakes
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-28-2009, 07:43 PM
