Thread: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lifter
Results 1 to 16 of 16
  1. #1 which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lifter
    Jul 2016
    New Jersey 5 min from DE
    Hello, my 09 SS is down currently for a collapsed lifter. I plan on doing the lifters myself and I'm going to tune out the Active Fuel Management while the car is down. My question is which lifters to go with? I read that some people are using the LS7 lifters now. ANy info would be appreciated! Here is a video of the car with the valve cover off
    https://www.youtube.com/watch?v=kRc-n6Altqc
  2. #2 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    You must swap the camshaft too, you can't just swap lifters. You have to do the full DoD delete if you really want it all gone.
    LS7's lifters are the most popular for the switch though.
  3. #3 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Jul 2016
    This isn't true, there are people that have kept the original setup and just had the AFM tuned out. I'm just wanting to upgrade since I already have a collapsed lifter
  4. #4 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    How are you going to get around the fact that the DoD lifters are different lengths, the lifters trays are different and the fact that the DoD cylinders have different lift ratings on each cam lobe.
  5. #5 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Magic
  6. #6 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
  7. #7 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Mar 2014
    Tucson
    Quote Originally Posted by cjdz24z28 View Post
    I think this part is true. You can keep the ENTIRE original setup and just turn off AFM/DOD and be fine.** No mechanical changes. Once you swap lifters, it's no longer the "original" setup. Does that make sense?
    Edit.
    **Assuming there are no mechanical issues. Seems to not be the case for OP.
  8. #8 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Wichita
    Just get a tune & if you feel you need to then replace the piston rings. Doing anything else is a waste of time & money if you aren't going for bigger cam/intake etc.
  9. #9 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Kemmerer, Wyoming
    this won't fix his broken lifter
  10. #10 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Wichita
    Haha guess that was in the title of the post. My mistake.
  11. #11 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Arizona
    If you swap all non dod lifters on a stock dod cam you will have misfires. Dod lobes on the cam itself are different than the non dod lobes. Just order a stock ls2 cam and call it a day and do it right if your going the cheap route. You still will want a ls2 timing set with damper.
  12. #12 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    I would still just tune the damn thing and put new lifters in it.
    It's going to be worlds easier than dropping the entire powertrain out of the car and putting a "stock" cam in there and gaining 20~ horse. Just not worth my time.
  13. #13 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Jul 2016
    Thanks for the replies. Yes Blueguy, I agree and not to put anyones car down because there are some quick cars here but to me these cars aren't worth modding alot due to the Fwd and the trans issues some have. I brought my SS as a daily driver. I plan on a catback ,tune and c.a.i. I do own a Cobalt SS and a 05 Corvette that I do mod
  14. #14 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    I'd get a trans cooler on that list.
  15. #15 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Arizona
    You can't tune out lifter failure. For the head to come off you don't need to drop the power train it can be done it in car
  16. #16 Re: which lifters for 5.3L LS4? Tuning out DOD while car is down for a collapsed Lift
    Quote Originally Posted by 91parkave View Post
    Never said it would; but nipping it in the butt if the car has low enough mileage could save it.
    I had mine tuned at 50~k.
  1. Lifter & lifter guide change HELP.
    By 97Darktealgp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2016, 10:34 PM
  2. Collapsed lifter (Maybe)
    By bjermane1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-08-2011, 11:16 PM
