Thread: misfire problems
Results 1 to 15 of 15
  1. #1 misfire problems
    May 2013
    chicago
    Has anyone heard of a brainbox issue which results in a misfire. Cylinder 1.
  2. #2 Re: misfire problems
    tune up coils, icm, those are the first stings to check.
    move plug 1 to 3, then the plug wire, swap two coils around. your looking to make the misfire move. last ditch effort is the injector swap around. then the icm to get tested at a parts store.
    unless your just long over due for a tune, just do that.
  3. #3 Re: misfire problems
    May 2013
    chicago
    icm means?
  4. #4 Re: misfire problems
    ignition control module. its what the coils are bolted to.
  5. #5 Re: misfire problems
    May 2013
    chicago
    Ok...done all that. Here's the situation, a mechanic told me i had a compression problem. Either a faulty injector or brainbox not sending correct voltage.
    Sent from my SM-G920P using Tapatalk
  6. #6 Re: misfire problems
    swap the injector then, check over your wires to the #1 injector.
    bad pcm dont normally cause just a misfire.
    and a injector wont cause a compression problem. think bad valve or f ed up piston.
    damn and your a v8, missed that part. same rules apply tho. move stuff till the misfire moves with it.
  7. #7 Re: misfire problems
    May 2013
    chicago
    Thanks bro! To be continued
  8. #8 Re: misfire problems
    If you have low compression, it's a possible DoD cylinder.
  9. #9 Re: misfire problems
    May 2013
    chicago
    What does DoD mean?
  10. #10 Re: misfire problems
    Displacement on demand, same as active fuel management.
    The LS4 has DoD and switches to 4 cylinders while at normal cruising speeds. The cylinders that shut down are known to burn oil and even sometimes lose compresssion. The other biggest failure if have the lifter sticked closed or ruin the camshaft.
  11. #11 Re: misfire problems
    Arizona
    Did the mechanic perform a compression check or was this a guess.
  12. #12 Re: misfire problems
    May 2013
    chicago
    He said he was gonna but im not sure if he did. Im starting to wonder if he's legit.
  13. #13 Re: misfire problems
    Arizona
    That's where I'd start hell rent one from autozone and do it myself
  14. #14 Re: misfire problems
    If you're even guessing the mechanic's work...I'd suggest finding a new one or learn from doing it yourself. At least you know it's getting done right even if it might take you longer since you've never done it before.
  15. #15 Re: misfire problems
    May 2013
    chicago
    I believe thats the route im gonna have to take. To much hustlin out here for me.
  1. HELP PLEASE! Misfire at 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2013, 05:34 PM
  2. Sparkplug and Misfire problems.
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 03:58 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. 2 different misfire problems fixed
    By GtpKo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 01:01 PM
  5. EGR valve problems and cyclinder misfire
    By rmortime in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2010, 11:59 PM
