So my gtp has been starting and dying unless I push on gas..had a engine light for egr so I replaced it but still is dyin. Any ideads? I'm guessing it's something with the electric throttle body as my regal and 2000 gtp never do this
Can I use brake cleaner? I removed intake and throttle body is filthy I'll prob have to remove it
Thanks! Hasn't died since, it was filthy! Now to figure out my miss issue..happens under 1800 rpm feels as if I'm running out of gas or something (falls on its face) but if I floor it or give atleast half throttle it comes right out of it
I had a bit of that. Are you using any coolant? Is there white smoke out the pipes at start up?
My daughters car doing this. Using coolant like crazy and see some smoke. Car stalling! Can you send me pick of throttle body and intake. Want to clean it up! Thanks!
