My 04gtp has 104s, 180 drilled thermostat, plog, 2.5 catless dp, ported lower intake, zzp pcm, wizaird intake, and throttle body spacer.
Right now it has a 3.6 pulley to drop to a 3.5 zzp recommends 1.9 rocker arms had anyone run a 3.5 without the rocker arms?
I do not have a scanner for kr and can not get elm327 to connect to the ecu.
Any advice on what kind of scanner to use and the 3.5 pulley set up?
Sent from my VS986 using Tapatalk
