Thread: Series III heads on series II motor
Results 1 to 15 of 15
  1. #1 Series III heads on series II motor
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    I'm just curious of this, consider SC cars only. I know the Series III heads have bigger valves and breath a bit better. So can you switch the Series III heads on to a Series II motor with little/no machine work?
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: Series III heads on series II motor
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Yup, they don't require anything special, your good to go.
    Edit: The difference in valve size is very small, you likely won't notice any gains just from that.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  3. #3 Re: Series III heads on series II motor
    Feb 2014
    Rhode Island
    Would it need a tune on the dyno afterward to compensate for the larger valves? Or is it just bolt up and go?
  4. #4 Re: Series III heads on series II motor
    redneck tennessee
    No tune, just bolt up, not really worth it if that's the whole reason for the swap tho.
  5. #5 Re: Series III heads on series II motor
    Feb 2014
    Rhode Island
    Any gains right off the bat, or does it just open up more potential? Not looking to swap as a must but I might consider if I see a Series III gtp in a junk yard haha
  6. #6 Re: Series III heads on series II motor
    redneck tennessee
    Its hard to say, I've got series 3 heads on my 98, but I couldn't tell you the difference, I did a full cammed build as I did it.I'm guessing you wouldn't even tell the difference, we're talking minimal valve difference.
  7. #7 Re: Series III heads on series II motor
    You won't notice ANYTHING.
    If anything, put headers on it while the heads are off.
    Then you'll notice some gains.
  8. #8 Re: Series III heads on series II motor
    Kemmerer, Wyoming
    I put ported L32 heads and an XP cam on my 2001 gtp and it made more power. I would never consider putting stock unmodified L32 heads on a car without having them ported with a valve job and at least 90 lb valve springs, and just doing heads without a cam or high ratio rockers makes no sense.
  9. #9 Re: Series III heads on series II motor
    Quote Originally Posted by SgtMarshal View Post
    It made more power because of the cam.
    The point is if you're just swapping heads, then there is no gains that you'll notice on the butt dyno. And if you do then your old heads had a mechanical issue.
  10. #10 Re: Series III heads on series II motor
    Kemmerer, Wyoming
    Quote Originally Posted by blueguy View Post
    I understand that, I just wanted to make an illustration of why someone would swap heads. ported heads support higher levels of power.
  11. #11 Re: Series III heads on series II motor
    I'd only swap heads if they were hogged out.
    Apparently OP is swapping stock for stock.
    Sooooo, yea.
  12. #12 Re: Series III heads on series II motor
    Kemmerer, Wyoming
    if the op did find a set of good L32 heads at the junkyard and the price was right, they would probably be worth buying, but only to port and install in conjunction with a cam. is this horse dead yet?
  13. #13 Re: Series III heads on series II motor
    I don't know, you keep beating it
  14. #14 Re: Series III heads on series II motor
    Feb 2013
    37.295091, -121.930053
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  15. #15 Re: Series III heads on series II motor
    Kemmerer, Wyoming
    nice
  1. leaking coolant at TB, possible top swap with series 3 on to a series 2 block?
    By anarchy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2013, 03:54 PM
  2. Porting Series II Heads?
    By indygrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2012, 09:16 PM
  3. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
