Thread: Tube between the air filter and intake manifold?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Tube between the air filter and intake manifold?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    FWIW Dexcool doesn't cause the intake gasket issues. It's only true claim to fame is potentially turning to oatmeal if air is introduced. Ford, Chrysler and GM all went nylon based (plastic) gaskets around the same time and all of them had the same issues.
    My GM truk had a trans drain plug. Maybe it's just the cheap GP that didn't have one.
    Do you have to point out everything I say wrong!!!??? Lol.
  2. #22 Re: Tube between the air filter and intake manifold?
    No, I could let you be stupid and never learn anything.
    I've changed coolant etc and seen the plastic gaskets look horrible in under 20K miles. It's the gaskets, not the coolant. Yet if you search the internet..you will find a lot of things saying it's coolant based. The coolant was oat based.. so it sludged. When you research an issue enough and you work on hundreds of cars and different brands/models you learn tons.
  3. #23 Re: Tube between the air filter and intake manifold?
    Buffalo
    Tastes like cherrios - dex cool
  4. #24 Re: Tube between the air filter and intake manifold?
    Enfield, CT
    Dude... Don't argue with people's ignorance. Its easier to keep them down. BTW I'm glad you understand the whole dex-cool/nylon 66 gaskets issues. I thought I was the only one who did enough real reasearch into the issue.
    Sent from my LG G3
  5. #25 Re: Tube between the air filter and intake manifold?
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #26 Re: Tube between the air filter and intake manifold?
    Feb 2010
    TN
    We all said JY and I never had a problem with Dexicool
  1. Corroded LIM Lower intake manifold Get new manifold or is this one ok
    By jj5428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2015, 07:04 AM
  2. Replies: 12
    Last Post: 09-04-2014, 05:24 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. EGR Tube to exhaust manifold
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 02:43 PM
