Thread: pcm questions - need help
Results 1 to 14 of 14
  1. #1 pcm questions - need help
    Jan 2009
    connecticut
    I have a 2001 GTP with 65,000 miles, I got the car 2 months ago and been slowly putting mods on it. So far I have installed 3" down pipe, high flow cat, u-bend delete, K & N CAI, and I have a 180 T-stat i'm going to put in when it gets a little warmer. I feel my next step is a pcm, I was thinking of going with DHP i've heard alot of good things about them. Any opinions? My question is, do I have enough done to my car to put the tuned pcm in and do I HAVE to drop pulley sizes in order to put the pcm in? will I feel a noticeable difference with the pcm upgrade and stock pulley? I'm new into the grand prix game, so all the help I can get would be greatly appreciated. Thanks
  2. #2 Re: pcm questions - need help
    DHP is a decent choice, but it is really a generic tune that isnt all that good. it adds timing and fueling, but ends up making the car run rich.
    if you want something more based on what youve got then look to Will Overkill.
    dont need to drop pullies, but why mod the car to support a smaller pulley and not do it? a 3.4 setup makes a world of difference as far as power from stock.
  3. #3 Re: pcm questions - need help
    Jan 2009
    connecticut
    I'm undecided about dropping pulleys, i'm just afraid it will kill the car. Is a 3.4 worse on the car mechanically? will a pulley make me feel a noticeable difference and do I have enough done to suport a 3.4? so far, what i've done I haven't felt any difference in power. I've also thought headers, maybe? I want noticeable power with out f*ck*ng the car up
  4. #4 Re: pcm questions - need help
    it isnt any worse on the car mechanically if you keep it from knocking and running in good health.
    with a 3.4, the car FEELS twice as fast, even though it isnt. id say with a little colder set of plugs and the tune with the PCM that youd be good with a 3.4. id be willing to say that you could run a 3.5 very easily (just for your knowledge, as a performance package SLP gave a grand prix GTX a 3.5 pulley).
    if youre that worried about it, grab a powerlog while youre looking for a PCM.
  5. #5 Re: pcm questions - need help
    Jan 2009
    connecticut
    I appreciate the help your giving me, I can't find websites to buy from for dhp or overkill. I know I should change the plugs, which are working well for people, i've heard autolites, but which do i use? or is irridiam plugs better? What are the benefits or a powerlog, is the like headers? what is the difference, I see people are only changing the front one, sounds kinda wierd without doing the rear one too. sorry if I sound dumb, i'm new to grand prix modding, I know how to work on cars but it seems much different kinds of mod than when I work on my camaro.
  6. #6 Re: pcm questions - need help
    Donating Users blowfishRus6's Avatar
    g.a.
    over kill is on here. go down to community vendors. powerlog is the front exhaust manifold. the stock one is very restrictive and powerlog helps get exhuast out faster.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: pcm questions - need help
    g.a.
    well vendor something
    :: Overkill Motorsports ::
    its slow.
  8. #8 Re: pcm questions - need help
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    if you arent going to get headers def. get a powerlog. it helped me a lot.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  9. #9 Re: pcm questions - need help
    Jan 2009
    connecticut
    I heard headers leak alot, will a powerlog be the same?
  10. #10 Re: pcm questions - need help
    headers dont leak if you arent a moron, but a powerlog has less chance of leaking.
  11. #11 Re: pcm questions - need help
    Jan 2009
    connecticut
    Where can I get a dhp pcm? By putting a pcm in, I don't have to worry about kr, only when/if I drop pulley sizes, correct?
  12. #12 Re: pcm questions - need help
    you will still have to worry about it, but the more you have done the less you should potentially knock with a bigger pulley. on a stock pulley any mods, especially a downpipe and intake, will usually drop your knock a lot if not completely.
    not sure if you can get a DHP PCM anywhere anymore. you might be best off going with intense or looking for someone local.
  13. #13 Re: pcm questions - need help
    Jan 2009
    connecticut
    I can't find DHP anywhere, which pcm is most favored for these cars, with the least problems zzp, intense, or overkill? And also, is it normal that when I go hard on the car for the rpm's to go up to like 6000, even though I had the stock pcm?
  14. #14 Re: pcm questions - need help
    g.a.
    overkill by far. pcm will firm up shifts so it wont take as long to shift.
    its slow.
  1. HV3 questions...
    By whitelightnin04MC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2010, 11:43 PM
  2. New - A few questions please
    By lioneyes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2008, 07:48 PM
  3. Questions
    By stkks in forum General Tech Discussion
    Last Post: 08-20-2008, 06:11 AM
  4. mod questions
    By kingd44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:04 PM
  5. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
