Thread: Best spot for the IC pump?
Results 1 to 7 of 7
  1. #1 Best spot for the IC pump?
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Initially when I installed my IC pump I put it in the fender area as seen per other threads. I was then told I cannot do this as the air will not be purged and the pump won't work well like this.
    Now being in New England I fear the pumps placement down by the frame with these up coming wet months.
    Where are all of you mounting your pumps???? Pro's cons if I put it back in the fender area?
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  2. #2 Re: Best spot for the IC pump?
    Dec 2013
    ohio
    Looks like how mine is set up. It took a bit to get the air out of the system but it works just fine. As long as the fill is high in the system. Not sure where a better place would be.
  3. #3 Re: Best spot for the IC pump?
    That steel subframe !
    04 Comp G.
  4. #4 Re: Best spot for the IC pump?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I just had mine laying on the plastic of the passenger fender liner, lines held it in place pretty good. I didn't remove the bumper either for my install, or uninstall when I switched to E85. Never even knew there was a con to mounting it in the fender area, always thought as long as it was the lowest point in the system it was good. I'm done with all that ic stuff now though, lol.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  5. #5 Re: Best spot for the IC pump?
    I vote garbage can is the best spot...... LOL
  6. #6 Re: Best spot for the IC pump?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Here is where I put mine when I was SCd.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  7. #7 Re: Best spot for the IC pump?
    Kemmerer, Wyoming
    when I initially mounted my intercooler pump, it went in the engine bay, right next to the pcm. I have since relocated it, and have it mounted directly under the spot it was previously mounted. I wanted to install a 97 style antifreeze coolant overflow to use for my intercooler, so that spot was no longer available.
  1. can you spot the bs???
    By mskram1 in forum The Rant Forum
    Last Post: 04-21-2013, 10:53 PM
  2. is there a better spot
    By 99NebraskaGTP in forum General Grand Prix Discussion
    Last Post: 09-22-2012, 02:51 PM
  3. Can you spot your car?
    By Slowpoke in forum General Grand Prix Discussion
    Last Post: 01-04-2012, 12:50 PM
  4. Can you spot your car?
    Last Post: 01-01-2012, 05:41 PM
  5. Can you spot the 'Wootage'?
    Last Post: 05-05-2008, 08:00 PM
