Hello, I'm new here but in desperate need of help and thought maybe I could get an answer here.
I have a 2002 GTP. I was cruising down the freeway at 70. My boost meter started freaking out going up and down up and down. Then the car started bogging out, slowing down. I pulled over and shut it off. When I started it back up to see what was going on under the hood, the car was sputtering and shaking pretty bad. The oil looks good, not milky. The motor has recently been replaced, and only had 59,000 miles on it when it was put in. The head gasket was replaced when the motor was swapped. The car itself has around 150,000. The motor didn't come come with a supercharger so the old one was used. Do you think the Supercharger is shot completely? Someone suggested O2 sensor, but it seems more severe than that.
