Thread: Transmission in 04 gtp comp G
Results 1 to 2 of 2
  1. #1 Transmission in 04 gtp comp G
    SE Level Member sshenry83's Avatar
    Jul 2015
    From what I've read the transmission in this 04comp G has different rear end gears than all other gtp's. And I've read th at only the comp G and one other thing like a Buick rendezvous are only trannys that interchange. Is that correct. I have a 97 Grand prix gt 3.8 and a 03 gtp supercharged 3.8. Won't either of these transmissions work
    Sent from my HTC Desire 510 using Tapatalk
  2. #2 Re: Transmission in 04 gtp comp G
    Both transmission will not be a direct swap.
    The 97 is vacuum assisted and could never work anyway.
    But you are right, the final gear ratio is different in a COMP G. They have 3.29's instead of the normal 2.93's in nearly all supercharged powered grand prixs, regals.
  1. WTB GTP Comp G transmission with no issues
    By mtgnhl2 in forum Wanted To Buy - Parts
    Last Post: 04-17-2015, 11:30 PM
  2. 2004 GTP transmission vs GTP Comp G transmission
    By Jordan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2014, 12:33 PM
  3. I think I made a boo boo Comp G transmission related!
    By htown se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-27-2013, 12:38 AM
  4. comp g transmission
    By 97grandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-23-2011, 03:53 PM
