Thread: Appropiate Torque specs for Rocker Arm Bolts
Results 1 to 12 of 12
  1. #1 Appropiate Torque specs for Rocker Arm Bolts
    Banned
    Jan 2013
    maryland
    In the middle of doin a rocker arm for a buddy doin a mild build and looked up a couple threads for Torquing rocker arm bolts want to know what are the appropiate torque specs for Stock Rocker arms with Reusable bolts? Thanks guys
  2. #2 Re: Appropiate Torque specs for Rocker Arm Bolts
    25 fp is what i was told to use. make sure the bolt holes are clean and dry.
  3. #3 Re: Appropiate Torque specs for Rocker Arm Bolts
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by ScottyBDoggs View Post
    Ok i will try that.. Scotty doggs.. Does is matter which bolt? He has reusable rocker arm bolts... Not the stock torque to yield bolts
  4. #4 Re: Appropiate Torque specs for Rocker Arm Bolts
    ive got re usable bolts thats what i tq em to.
    iirc, jay, bill and greg all said the same tq @25.......and i just set them to the same last week when i put my rockers on the new engine.
  5. #5 Re: Appropiate Torque specs for Rocker Arm Bolts
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    oem bolts are tq to 11, reusable ones, comp, arp, etc @ 25
  6. #6 Re: Appropiate Torque specs for Rocker Arm Bolts
    Banned
    Jan 2013
    maryland
    Ok cool thanks .. Also.. Which size fits the reusable bolts? i have a duralast allen key size 6 socket but its stripping the bolt when i torque it.. Buddy purchased them from ZZP site im oddly enough finished with the rear the front is what is giving me a little issues
  7. #7 Re: Appropiate Torque specs for Rocker Arm Bolts
    The ones I got were 3/8s 12 point bolts.
  8. #8 Re: Appropiate Torque specs for Rocker Arm Bolts
    i took mine into HF then matched them up to what fit best, iirc im using a standard size allen socket.
  9. #9 Re: Appropiate Torque specs for Rocker Arm Bolts
    Banned
    Jan 2013
    maryland
    Ok i will take one to a store its about to rain like sh** tried to finish it for him right now cuz he is crying about a date in a hr... He should have waited till next week lol thanks again guys
  10. #10 Re: Appropiate Torque specs for Rocker Arm Bolts
    Mar 2014
    Tucson
    5/16' SHCS = 1/4" Hex. SAE standard.
  11. #11 Re: Appropiate Torque specs for Rocker Arm Bolts
    GXP Level Member
    Mar 2015
    Tomball
    Can you reuse the TTY rocker bolts by torquing them then the proper number of degrees past? I did this on several 3.1's when doing LIM's and didn't have a problem. Just wondering if I got lucky due to EFS, for head bolts I wouldn't do this but I figured rockers shouldn't be a big deal.
    Jeff
  12. #12 Re: Appropiate Torque specs for Rocker Arm Bolts
    Banned
    Jan 2013
    maryland
    I always thought that.. Couod anybody chime in? On reusing tty rocker bolts?
  1. Rear 2007 Grand prix GXP 4 bolt hub bolts torque specs
    By demonickronik57 in forum Brakes/Suspension/Chassis
    Last Post: 11-05-2012, 12:34 AM
  2. Comp Cams Re-useable rocker bolts - torque spec?
    By Elite6 in forum General Tech Discussion
    Last Post: 07-14-2012, 02:51 PM
  3. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  4. Torque specs
    By projectGTP in forum General Tech Discussion
    Last Post: 03-25-2009, 07:31 AM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
