Get a small piece of wire so you can probe the contacts for the fp relay and check for 12V. But try the battery disconnect and relearn first.
Jeff
Jeff
Clear dtc's too. I think its p0169? It sets every time I flash a tune.
how can I clear the DTC's if I can't even get the car to start?
Aeroforce won't turn on for an extended period of time with the car off. Car needs to be running.
Oh. Most scanners you don't have to have car running. Didn't know about the aeroforce. Odd.
That's what I just hit me. I didn't unplug the battery when I swapped PCM's the first time. Would that cause an issue?
Next step is to jump the relay.
I'll give it a try, but last time I turned the key on engine off, the aeroforce lit up, but shut off 10 seconds later.
Going to give that a try right now.
What about not unplugging the battery first before swapping PCM's? Is that going to cause some kind of Crank, no start issue?
Think I found the issue.
-Bent the tab to run the pump at full speed, still no start.
-Cleared any codes I had with the aeroforce, still no start.
-Removed the fuel pump relay and jumped the relay with a small wire, and heard the whole fuel system kick on.
Fuel pump relay must have taken a sh*t. Odd how it did this when I swapped PCMs though?
Ouch should have mentioned disconnecting the battery. It may or may it be a problem, but always disconnect the battery any time you switch out a component that could be powered.
so Scotty doesn't the system start by bypassing the resistor to start? 85 is the negative relay coil so basically it stays normally closed, which would mean that this relay handles high/low speed and there must be another that turns on the fuel pump. Is this correct?
Kinda like my injector sticking open right after a supercharger swap. It happens especially with higher current relays. I've sat on th side of the road and dismantled a relay with a pocket knife and rubbed the contacts together to get it to work to get me home before when I had no other tools.
Mat least it's just a relay.... For now.
Jeff
Lesson learned on not unplugging the battery, especially for such a critical component. Luckily, I think everything came out okay besides the relay, but I'll take that over a bigger issue.
What should have been a 5 minute job, turned into a 3 hour diagnostic testing.
That's why I grabbed a pocket full of relays last time I was at the yard. Nice to have in the glovebox for times like this.
Welcome to my world. ( devilish laugh)
Jeff
Autozone carries the fuel pump relay for my car, but cost me $18. .
Anywho, knock sensors are plugged back in and the ZZP PCM is installed. Once I get the car running and buttoned up, I'll come back with some info on the Cruise Knock.
Stop by 3 parts stores the other day looking for one and none of them had one in stock, yea they could order it but I'm not spending $20 on a fuse just to troubleshoot then I remember the zip lock bag of fuses I've gathered from JY cars over the years
Dude if you have another car and a pick-n-pull close to you then it would worth the time to pull a many of the little ones the larger ones and some fuses. You'll get out of there under $20. I think last time I got some they were .75 each. For relays and fuses were free, or they didn't charge me for them.
Jeff
