Thread: Strange coolant temperatures.
Results 1 to 9 of 9
  1. #1 Strange coolant temperatures.
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Hello forum.
    Its getting hot out here in Atlanta. Noticed my gauge cluster temp gauge reading a bit high in traffic. Switched over the Aeroforce and it was reading 233deg at the stop light. Pulled over, popped the hood expecting a coolant leak.... Nothing. Topped off the coolant reservoir and made it home. Aeroforce was averaging about 204deg with a low of 195deg on a long stretch of highway.
    I have had a 180deg T-Stat on the car for about 7 years and I have never seen it get this hot. In the morning im going to bleed the system and drive it around to check the temps.
    Im thinking the T-Stat is stuck open. What do yall think?
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  2. #2 Re: Strange coolant temperatures.
    SWPA
    If t-stat was stuck open you'd be running cooler.
    If you have a 180 T-stat and did not tune for it the fans will not come on until 210.
  3. #3 Re: Strange coolant temperatures.
    Atlanta, GA
    It is tuned for the 180 deg t stat.
  4. #4 Re: Strange coolant temperatures.
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Tell me you've done at least 1 coolant flush within those 7 years, lol.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  5. #5 Re: Strange coolant temperatures.
    Atlanta, GA
    lol yes I did a dextron delete as soon as i got the car. Have done flushes about once a year for good measure.
  6. #6 Re: Strange coolant temperatures.
    I'd pop a new 10 dollar thermostat in there just for kicks.
  7. #7 Re: Strange coolant temperatures.
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Even with stock settings, 233 is hot. I have an ever so slightly failed head gasket and my car doesn't get that hot with the 195. Even further, I am just north so we are comparing at the same temps.
    When my fans finally kick on (226 or so) the temps plummet back to 210.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  8. #8 Re: Strange coolant temperatures.
    Jan 2014
    United States
    If I was you Id begin looking at the coolant pump or the radiator.
    Id Do a flush
  9. #9 Re: Strange coolant temperatures.
    Atlanta, GA
    Flushed the system, bled, topped off. Coolant temperatures average 170-185 deg around town. There had to be an air bubble in the system even after I bled it before the flush. I may stop topping it off in the overflow tank and just use the radiator filler cap.
  1. Delayed shifting in temperatures below freezing
    By Mbeejonhn in forum General Grand Prix Discussion
    Last Post: 03-30-2015, 12:01 AM
  2. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  3. 97 Grand Prix Normal AC Vent Temperatures and Pressures
    By mainecrab in forum General Tech Discussion
    Last Post: 07-08-2014, 08:48 PM
  4. Strange Coolant issues
    By Talon62 in forum General Tech Discussion
    Last Post: 06-18-2012, 07:44 AM
  5. 96 Grand Prix 3.1 Low Coolant light on & AC acting Strange
    By tallcar in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-21-2009, 05:14 PM
